Front Brakes - Pressure Builds, Eventually Locks Up - Road Glide Forums
 2Likes
  • 1 Post By ChromeSpark
  • 1 Post By Thermodyne
post #1 of 4 (permalink) Old 10-08-2018, 10:49 AM Thread Starter
Shrug's Avatar
Interesting phenomenon with my front (2010 FLTRX non ABS) brakes. Pressure at the lever will build up to the point the lever has no pull and the brakes eventually slowly lock up. I had to bleed pressure at the caliper to release the pads from the rotor and get some give in the lever. The problem repeated itself again (no pullback in the lever) after the bleeding, but the fluid level was low enough that the brakes didn't lock.
I don't think it's a heat issue as the lever was very stiff when I first started the bike.
Any suggestions?
Shrug - Scott Wilson
2010 FLTRX "Hester 2.0" -
Shrug is offline
post #2 of 4 (permalink) Old 10-08-2018, 10:57 AM
ChromeSpark's Avatar
Just a guess, the fluid return hole in the master cylinder is blocked?
Stoic Joker likes this.
"It's a motorcycle, itīs not supposed to be comfortable, quiet or safe. The wind noise is supposed to hurt your ears, the seat should be hard and riding it should make you s**t your pants every now and then."
ChromeSpark is offline
post #3 of 4 (permalink) Old 10-08-2018, 11:44 AM
bucketlisthd's Avatar
I think Chromespark nailed it. It happened on my Venture. There are 2 holes in the MC. The return hole is very small and hard to see, as I recall.
'15 Roadglide Special
'87 FXR 100"
'79 Goldwing cafe
bucketlisthd is offline
post #4 of 4 (permalink) Old 10-08-2018, 02:11 PM
Thermodyne's Avatar
When the pressure has them bound up, loosen the banjo bolt at the master cylinder. If that releases the pressure, rebuild the master. If not, then open the bleeders. If that releases the pressure, replace the brake line. If neither released the pressure, un bolt the calipers and see which one is bound up. Then rebuild them both and pay close attention to the one that bound up. It might need a piston or two. Or even replacing if the casting has degraded.
Mike U likes this.
Thermodyne is offline
Low compression 117 builds for the M8 rdc401 *General Road Glide Discussions/Pictures 2 08-29-2018 10:22 PM
1-forty-1 speed shop builds? cookie114 Engine Related 3 04-10-2017 08:05 PM
front brakes lock up dfachner Troubleshooting for Road Glides 9 10-12-2013 08:52 PM
Best saddlebag locks ??? THEMASTERDESTROYER Aftermarket Accessories 9 11-28-2011 06:37 PM
