08 RG Handlebars turned to the right - Road Glide Forums
post #1 of 2 (permalink) Old 10-08-2018, 03:45 PM Thread Starter
Hi Iíve searched through the forums couldnít find the thread for handlebars being off center.
Is it an easy fix? Also 25,000 on bike and read a few post about riser bushings. What would new risers bushings do for me?
Thanks
Tim in Indy
timmyj77 is offline
post #2 of 2 (permalink) Old 10-09-2018, 07:27 AM
Thanks
Tim in Indy
Where the bolts go up through the top triple tree, into the bottom of the risers, there are bushings around those bolts to help dampen vibrations that would otherwise transmit to your hands. If those bushings are worn (compressed), then your bars could look "turned" when compared to the upper triple tree. If your bars are to the right, you could try an easy fix. Loosen, but don't remove, the riser bolts from underneath (you'll need a 3/4" socket and long extension), and the turn your handlbars to the left. Once you hit the forkstop, push a little harder to the left and see if that corrects you problem. If it does, retorque the risers bolts underneath to factory spec.
Sometimes handlebars will also get "turned" when the riser cap bolts are over tightened and/or not cross pattern tightened. As the riser cap is pulled downwards, it will move the bar towards the bolts that aren't as tight, which can result in "turning".
2018 FLTRXS Wicked Red
Harley Master Tech
crazy4ink is offline
Right place. Right time. RFG7680 *General Road Glide Discussions/Pictures 10 09-24-2016 10:45 PM
Need some help getting the right size handlebars jayfire Controls & Handlebars 3 02-21-2014 09:34 AM
Handlebars THUNK when turned Mcrider996 Controls & Handlebars 1 05-28-2012 09:58 PM
Bike turned Black!! hodgeaaco *General Road Glide Discussions/Pictures 20 07-09-2010 08:30 PM
HD Handlebars 56166-08 for 09 RG HDKid Controls & Handlebars 0 04-27-2010 09:05 PM
