Factory 47 12in -Problems - Road Glide Forums
 11Likes
post #1 of 12 (permalink) Old 10-11-2018, 12:31 AM Thread Starter
I just got 2019 Road Glide special. I bought New Factory 47 12in. I watched the video and took my time putting the wires through the bars. When I plugged everything back in nothing works. The controls on both side won't work, the gauge cluster has no power. I did not unplug the battery when I did all the work (I know that was stupid). The only fuse box I found was on the left side with only 6 fuses ( all good). Any suggestions would be appreciated It seems like it should be a fuse since nothing works.
RustyStolzz is offline
post #2 of 12 (permalink) Old 10-11-2018, 01:27 AM
texasnurse's Avatar
Check the main fuse, you should have removed the fuse prior to disassembly.
wevsspot likes this.
texasnurse is offline
post #3 of 12 (permalink) Old 10-11-2018, 06:32 AM
Not unhooking the battery shouldn't have messed with anything. Double check the small plugs for your switch packs coming out of your bars. Since they are the same, it's easy to mix them up.
madmat and Nutt2336 like this.
2018 FLTRXS Wicked Red
Harley Master Tech at Hampton Roads Harley in Yorktown, VA
crazy4ink is offline
post #4 of 12 (permalink) Old 10-11-2018, 10:35 AM
Swoop76's Avatar
Had the same issue when did a bar swap, turned out had right side control wire was pinched and a bit loose.
Swoop76 is offline
post #5 of 12 (permalink) Old 10-11-2018, 12:14 PM
BH#103's Avatar
Sounds to me like the main fuse or you forgot to plug in all the connectors.
"SLIVER"
BH#103 is offline
post #6 of 12 (permalink) Old 10-11-2018, 01:55 PM
federal officer's Avatar
same thing happened to me buddy. double check you small 5amp acc fuse. that was my issue.
federal officer is offline
post #7 of 12 (permalink) Old 10-11-2018, 02:16 PM
wevsspot's Avatar
@RustyStolzz
Turn the ignition switch to the ON position. Does anything else power up? i.e. lights, radio, fuel pump prime?
Yes - make sure you plugged everything back in, remove the gage cluster and make sure the gage cluster plug is securely connected to the back of the gage cluster, and then make sure that all of your switch housing wires and TBW wires are plugged into the appropriate connections inside the cluster housing. If all that checks good, loosen and remove switch housings and make sure that you didn't pinch any of the wires coming out of the handlebars and going into the switch housings.
No - check 50A fuse under left side cover (hint it's the big red maxi-fuse )
wevsspot is offline
post #8 of 12 (permalink) Old 10-13-2018, 11:48 PM Thread Starter
Fixed It!!
First I want to thank you guys for the help!
So I had to wait a few days to work on the bike and started with checking the fuses. I found a blown fuse I had missed the night I was working on it. When I replaced it everything but the right side controls worked. I then checked to make sure the wires and the were pinched or loose. They weren't pinched! they must have been loose because after I disconnected and reconnected them everything worked! I love the Factory 47 12in bars. Much better (in my opinion) then the factory bars. I'm loving the Road Glide!
madmat and BigBlockBobby like this.
post #9 of 12 (permalink) Old 10-14-2018, 07:26 AM
madmat's Avatar
Congrats on your fix!
I beleive we will need picture proof that they are on the scoot!
OEM bars for me are not comfortable.
MightyWhitey likes this.
18 RGS Bonneville Salt Pearl
madmat is offline
post #10 of 12 (permalink) Old 10-16-2018, 09:56 PM Thread Starter
Here she is!
Here she is!
File Type: jpeg 0FBC5A36-CF7D-4104-A403-538FEA809E70.jpeg (158.7 KB, 92 views)
madmat, flhman, till66 and 2 others like this.
12" factory 47 malo for 2015 special dware15glide Controls & Handlebars 91 04-06-2017 08:59 PM
Just ordered my new 2015 factory 47 (formerly Buky Bars) road glide bars Wotsrab Controls & Handlebars 33 05-03-2016 11:04 PM
Factory 47 / Buky Bars cruznmarine Controls & Handlebars 37 04-27-2015 12:54 AM
Road glide hand guards on 14 inch Buky bars ( factory 47 ) opinions? ccsolo24lal Controls & Handlebars 33 03-15-2015 12:32 PM
Factory 47 rg113 Controls & Handlebars 22 02-07-2015 11:25 AM
