Bushings - Road Glide Forums
 4Likes
  • 2 Post By rlaf75
  • 1 Post By mfgator
  • 1 Post By BB Bomber
post #1 of 7 (permalink) Old 11-11-2018, 12:47 PM Thread Starter
DeneFLTRX's Avatar
Bushings
There is lots of great info on bar styles and sizing for various individuals on this forum but what about replacing the stock bushings while we change the bars out?
Are the stock mounts good enough these days or should one change them out?
What brand and material do we go with and I assume they’re not too hard to do?
On my ‘15 SGS I put on Wild1 10” bars and didn’t think to change anything else, it was fine.
2019 FLTRX, “Fin”
DeneFLTRX is offline
post #2 of 7 (permalink) Old 11-11-2018, 12:59 PM
it is recommended to replace the riser bushings when you replace the bars. is it necessary to do so? not unless your bars feel loose. I replaced my bars years ago without changing the bushings and they are just starting to feel loose. I will do them this winter though. it is also recommended to replace them with polyurethane bushings as they will/should last longer and they will feel stiffer for a more firm feel. as far as companies to buy the from its hard to say as there are many different brands available.
Buzzy and DeneFLTRX like this.
post #3 of 7 (permalink) Old 11-11-2018, 02:14 PM
BH#103's Avatar
In my personal experience and on any jobs I do I will recommend and install poly bushings with the slightly longer HD bolts. I have used the bushings from Drag Specialties without any issues, but like @rlaf75 stated there are a lot of companies to get them from.
"SLIVER"
BH#103 is offline
post #4 of 7 (permalink) Old 11-11-2018, 05:16 PM
mfgator's Avatar
Bushings
When I put on the 14” bars, I changed the bushings to poly. I would not have changed them for 10” or 12” bars. One thing I found is with the harder bushings I get a little more vibration to my hands. I like the tight feel of the bars.
Big_gary likes this.
mfgator is offline
post #5 of 7 (permalink) Old 11-11-2018, 08:25 PM
BB Bomber's Avatar
Changed mine out to poly as well when I put on 12". Arlen Ness, they were only like $10 there abouts. Like bh103 mentioned, get the slightly longer bolts. Poly bushings don't compress as much like rubber ones. I don't really notice any more vibration when moving.
BB Bomber is offline
post #6 of 7 (permalink) Old 11-11-2018, 09:27 PM Thread Starter
DeneFLTRX's Avatar
I’ll be down at my dealer this weekend and I’ll see if they sell them as well as longer bolts.
Next question, are they hard to install, ( no pullers needed etc)?
2019 FLTRX, “Fin”
post #7 of 7 (permalink) Old 11-12-2018, 11:41 AM
BB Bomber's Avatar
They pull out with right combination of cuss words. Easy peasy. No extra tools needed.
A little hint when putting in the bottom half of the right side. Put the bolt in the bushing first, then slide it in the bottom of the neck.
DeneFLTRX likes this.
Handlebar Riser Bushings for Apes? Tek74 Controls & Handlebars 3 02-24-2012 12:33 PM
2,500 miles - pulled lower fork sliders, should i install new seals/bushings? modot66 Suspensions 8 02-23-2012 11:33 PM
Bushings for the 14 wild1 chubbys fosterp Controls & Handlebars 7 01-18-2012 08:40 PM
Question for those that changed out to poly bushings and brake lines leeinmemphis Controls & Handlebars 8 08-02-2011 09:59 PM
Riser bushings? AZCFH Troubleshooting for Road Glides 4 01-22-2011 10:59 AM
