Heated grips - Road Glide Forums
post #1 of 7 (permalink) Old 11-18-2018, 11:52 AM Thread Starter
outlawrench's Avatar
Heated grips
Went to the local shop yesterday and bought the new kahuna chrome heated grips for my 19. I also bought the “required electrical connection update kit.” Came home from the store opened everything up and started reading directions. I decided to get the grips on first then worry about wiring after. I got the wires ran through the handlebars hooked up all the connectors under the gauges and put the front end back together. It was almost 10 getting that much done so I decided to leave the rest for today.
This morning I went out and installed my mustang solo seat so I could make sure the controls were in the right spots. I flipped on accessory power to listen to the radio. I had turned the heated grip switch on last night and it was still on this morning. All of a sudden while looking at my bars/controls/mirrors I realized my hands were getting warmer. The power connector under the gauges is hot....why then is the 40 dollar bag of electrical connectors necessary?
2018 FLTRX Denim Black -Traded in
2019 FLTRX Industrial Gray
outlawrench is offline
post #2 of 7 (permalink) Old 11-18-2018, 05:40 PM
MyGlide's Avatar
Good question. I just got new bars put on my bike and was thinking of adding the heated grips myself at a later time, but was under the impression there was a kit I had to get to run wires back under the tank to the battery. So yours worked simply by plugging in the connectors already there?
2018 FLTRU (mistake)
2018 KTM Super Duke R
MyGlide is offline
post #3 of 7 (permalink) Old 11-18-2018, 05:43 PM Thread Starter
Yes on my 19 there was a switched power wire with the correct connectors installed for the heated grips. But the Harley site and catalog claim you need an extra kit.
post #4 of 7 (permalink) Old 11-18-2018, 05:50 PM
MyGlide's Avatar
You wouldn't happen to have a pic by chance would you? If I remember correctly I had an extra connector not being used under my gauges.
MyGlide is offline
post #5 of 7 (permalink) Old 11-18-2018, 06:20 PM
On models other than Road Glides, you need the electrical connections kit to connect the heated grip power pigtail up in the fairing. On the Road Glides, there is a connector in the nacelle.
2018 FLTRXS Wicked Red
Harley Master Tech
crazy4ink is offline
post #6 of 7 (permalink) Old 11-18-2018, 06:24 PM Thread Starter
I don’t have a picture. It was a small square 2-pin connector on the left side with a filler plug in it.
post #7 of 7 (permalink) Old 11-18-2018, 06:25 PM Thread Starter
The kit I bought for the road glide had a fused positive link from the battery to repin a connector under the right side cover.
Heated gloves / heated grips with apes Steelerdude1 *General Road Glide Discussions/Pictures 7 11-01-2018 09:33 AM
Heated gloves Vs heated grips MarkL *General Road Glide Discussions/Pictures 16 10-21-2018 06:05 AM
Heated Grips Vs. Heated Gloves Big Spoon Aftermarket Accessories 24 12-26-2016 09:36 PM
Heated Gloves or Heated Grips BlackDangerous Clothing 50 05-02-2013 09:10 PM
Heated Grips vs Heated Gloves? sojourner Aftermarket Accessories 10 06-09-2010 01:02 PM
