Pull main fuse vs. disconnecting ground - Page 3 - Road Glide Forums
 8Likes
post #21 of 23 (permalink) Old 02-10-2019, 10:58 AM
geo8866's Avatar
Originally Posted by RGKen View Post
You do know to turn your ignition switch on and then when you turn it off you have to pull the main fuse within 5 seconds so you don't set off the alarm. Even if you don't have the audible alarm you still need to do it so that the security system is disabled while you pull the fuse.
Didn't know that either. Thanks Ken
geo8866 is offline
post #22 of 23 (permalink) Old 02-10-2019, 01:11 PM
RGKen's Avatar
I was actually wrong about this in that it doesn't apply to bikes without the audible alarm. Bikes without the audible alarm you can just pull the fuse.
geo8866 likes this.
2018 FLTRXS
RGKen is offline
post #23 of 23 (permalink) Old 02-12-2019, 07:10 PM
Phantom6722's Avatar
[QUOTE=Thermodyne;4571499] Or I should say, pulling the main fuse with the key on is the way to do it. It disarms the security if equipped,
+1exact what's in my user manual.
Cheers Skip
Phantom6722 is offline
should i pull maxi fuse before bar install? Jersey Drew Controls & Handlebars 8 06-05-2018 12:10 PM
Stock vs Arnott vs Legends vs HD Premium SEsupply2 Suspensions 15 04-25-2017 10:10 AM
Disconnecting fuel line Chuck1073 *General Road Glide Discussions/Pictures 6 03-20-2016 07:35 AM
Help with main ground wire. cruznmarine Audio 15 02-11-2014 01:12 AM
40 amp main fuse twowheel99 Do-IT-Yourself 4 03-05-2011 05:55 PM
