KST Bar Install-Clutch/Brake Perches? - Road Glide Forums
 12Likes
post #1 of 24 (permalink) Old 01-01-2019, 02:39 PM Thread Starter
18 Wicked Special's Avatar
I'm installing a set of 10" KST Renegade bars. Inside the front halves of the clutch and brake perches, there is a tit that engages into the stock bars that are drilled for it. On the KST's it's not drilled there. Not sure if all the aftermarket bars are this way. Do I need to grind off the tit? Can't see drilling the bars, KST would've done that .
18 Wicked Special is offline
post #2 of 24 (permalink) Old 01-01-2019, 02:59 PM
craigffb's Avatar
Yep, grind them off. For me that was the most time consuming part of the install.
18 Wicked Special likes this.
craigffb is offline
post #3 of 24 (permalink) Old 01-01-2019, 05:17 PM
rider17's Avatar
That is why I stayed with F47 they had the slots.
Sent from my Pixel 2 XL using Tapatalk
RFG7680 likes this.
2017 Road Glide Special Denim Black
If the path be beautiful, let us not ask where it leads - Anatole France
rider17 is offline
post #4 of 24 (permalink) Old 01-01-2019, 06:03 PM
I’ve installed a number of KST bars at work and I always just stand the clutch and brake perch on end on my toolbox and smack the pin with a punch. 95% of the time, the nub snaps off flush.
2018 FLTRXS Wicked Red
Harley Master Tech
crazy4ink is offline
post #5 of 24 (permalink) Old 01-01-2019, 06:19 PM
I ground mine off with a dremel.
Buzzy is offline
post #6 of 24 (permalink) Old 01-01-2019, 07:45 PM
craigffb's Avatar
Originally Posted by crazy4ink View Post
Iíve installed a number of KST bars at work and I always just stand the clutch and brake perch on end on my toolbox and smack the pin with a punch. 95% of the time, the nub snaps off flush.
Dang. That would have saved me like 30 minutes.
craigffb is offline
post #7 of 24 (permalink) Old 01-01-2019, 08:36 PM Thread Starter
Thanks! The dremel tool did the trick. Gives you full adjustment range. Pulled the bar clamp dowel pin too. HD must be using the pins for more efficient assembly. Never seen them on any previous bikes.
For $185 less than Factory 47, removing the pins isn't a big deal.
post #8 of 24 (permalink) Old 01-01-2019, 09:38 PM
bucketlisthd's Avatar
I used a screwdriver as a standoff and hit it with a hammer. They break off cleanly. It's quick and easy, really it is.
'15 Roadglide Special
'87 FXR 100"
'79 Goldwing cafe
bucketlisthd is offline
post #9 of 24 (permalink) Old 01-01-2019, 09:47 PM
MCRGS18's Avatar
About the same as what I did, took a 1/4 inch chisel, knocked off the pins, and sanded to make look good; although it will never be seen.
Efficiency maybe the end result, but in HD's case it was cost cutting one person assembly versus the need of two on the old road glides.
MCRGS18 is offline
post #10 of 24 (permalink) Old 01-02-2019, 03:57 PM Thread Starter
We're saying the same thing(cost cutting and efficiency}, streamlining the production process.
KST Renegade install advice 2018 FLTRU GlideDriver Controls & Handlebars 2 05-08-2018 04:23 PM
KST bar install Brake reservoir issue 407Driver Controls & Handlebars 0 08-28-2014 08:50 PM
Pre-install Brake/Clutch cables? Mason417 Controls & Handlebars 0 04-23-2013 09:32 PM
14" KST Mayhems - Help on install outlawjessejames Controls & Handlebars 3 03-12-2013 10:53 PM
Brake & Clutch Lever Install jimmyray11349 *General Road Glide Discussions/Pictures 3 08-03-2011 10:29 AM
