afetrmarket oil pressure gauge kit for my 2018 harley road glide - Road Glide Forums
post #1 of 10 (permalink) Old 01-17-2019, 09:44 PM Thread Starter
Luckys2018RoadGlideCustom's Avatar
Hi guys, me again
I got a 2018 harley road glide with no stock oil pressure gauge on my instrument cluster but Id like to add an aftermarket oil pressure gauge but no one stocks or makes any type of aftermarket oil gauge kits. You guys know of any aftermarket oil gauge kits I can pick up to add on my bike?
Or even in pieces to buy specific parts for making an aftermarket oil pressure gauge kit, any ideas of where I can go??
Thanks
John S
Luckys2018RoadGlideCustom is offline
post #2 of 10 (permalink) Old 05-28-2019, 12:08 AM
Mike15RG's Avatar
Did you ever find anything? I am searching for an oil psi gauge for my 15. I installed the Sony radio and lost factory gauge.
Thunderheader, Woods 555 cams, Power Vision, Sony radio, Rockford/Hertz speakers.
Mike15RG is offline
post #3 of 10 (permalink) Old 05-29-2019, 09:34 AM
texasnurse's Avatar
Wouldn’t be too difficult to add an inline gauge to the lines on the oil cooler.
(Edit:Its been done)
https://www.hdforums.com/forum/milwa...ure-gauge.html
texasnurse is offline
post #4 of 10 (permalink) Old 05-29-2019, 09:42 AM
texasnurse's Avatar
https://www.arlenness.com/prodcat/oi...gauge-kits.asp
For Twin Cam
post #5 of 10 (permalink) Old 05-29-2019, 07:53 PM
Mike15RG's Avatar
For Twin Cam
When you look at the notes it says not for baggers with stock oil gauges.
Mike15RG is offline
post #6 of 10 (permalink) Old 05-29-2019, 11:03 PM
texasnurse's Avatar
Do you have a factory gauge in the oil port?
Because the kit runs the gamut of many bikes, some of those bikes had an optional gauge. The gauge is a simple pressure switch; if nothing else call Arlen Ness prior to purchase.
post #7 of 10 (permalink) Old 05-30-2019, 07:01 PM
Mike15RG's Avatar
I am going to get a hold of them. I wonder if you can just install a T fitting were the factory sending unit is and run both the stock and aftermarket unit as well.
Mike15RG is offline
post #8 of 10 (permalink) Old 05-30-2019, 08:09 PM
UT_Larry's Avatar
Are you aware that you can use the right hand info switch and display it on the radio?
UT_Larry is offline
post #9 of 10 (permalink) Old 05-30-2019, 08:38 PM
gldlver's Avatar
it only shows OK not a PSI reading
Plus some guys have different head units and that great Idea by Harley to only put OK is gone.
But I do believe if you want to drop some coin the Dakota Digital gauges give the PSI as an option
gldlver is offline
post #10 of 10 (permalink) Old 06-25-2019, 01:17 PM
Arlen Ness gauge works
i'm running the Arlen Ness gauge on a 19 RoadGlide. only issue is the mounting bracket doesn't work as nice as it does on the twin cams. so i used the rear rocker box bolt and the rear mounting hole on the kit. Works great.
Birch is offline
2018 Road Glide Special wevsspot Audio 1 06-19-2018 08:20 PM
Harley Davidson Road glide Faring Mount bykw2 Parts for Sale 1 06-14-2018 09:52 AM
Vivid Black Paint Code MightyWhitey Paint & Bodywork Section 13 02-02-2017 07:21 PM
2015 Harley-Davidson Road Glide First-Ride Review VS Jeff Home Page News 0 07-22-2015 11:14 AM
My first Harley and it is a 2015 Road Glide Special wheels_up New Members Welcome Area 21 06-28-2015 10:04 PM
