Opinions on new bars. - Road Glide Forums
 5Likes
post #1 of 16 (permalink) Old 01-22-2019, 05:35 AM Thread Starter
schafered08's Avatar
Love the angle hook design but not sure what a quality brand is? Also have a few other questions for your guys opinions. Does a 1.5 bar fit with stock setup? And anyone have issues running heated handgrip wiring through it?
Also will be doing it myself since Harley wants to charge a outrageous amount as always.
~Cheshire
“Don’t fear dying, Fear not living”
schafered08 is offline
post #2 of 16 (permalink) Old 01-22-2019, 06:06 AM
The 1 1/2" bar is usually 1 1/4" where it clamps to the bike. You just need to confirm it. A lot of 1 1/4" bars taper at the clamp area to 1" so an after market clamp is required for these as well. Depending on the year of your bike you have to remove pins from an electrical connector, but there are plenty of videos on how to do this. On the 2018 I have it was not necessary to de-pin anything. I have done a bar swap for myself several times. The last time it took about an hour and a half.
Good bars? There are a lot of opinions and depends on personal preference. I have personally had and like the quality of, Vindikta, Factory47, Harley Tall boys and KST.
I have never run heated grips, but I am sure they will go through. The sharp angles can be difficult.
Good luck!
schafered08 likes this.
dbeny is offline
post #3 of 16 (permalink) Old 01-22-2019, 07:04 AM Thread Starter
What did you find best for routing the wires through your bars? I have a 2018 as well.
~Cheshire
post #4 of 16 (permalink) Old 01-22-2019, 08:04 AM
RFG7680's Avatar
The fatter the bar the easier to feed the wires. I have the Factory 47s 12". They're 1.5" and 1.25" at the clamp. Made for our bikes. Holes for the pins everything is in its place. Use a bead chain first. It falls right through the bars. Then I pulled some surveyors string back through. Then taped the wires on and fed them through. That was on a set of Road6 13" bats I did. Easy as can be. My dealer put my F47s on. I shamed them I to doing it for 2 hours labor since the bike was in there all winter and they were doing my frontend anyway.
RFG7680 is offline
post #5 of 16 (permalink) Old 01-22-2019, 08:31 AM
I used a pull chain. I know the dealer used an old break cable and silicone spray. The spray really helped.
dbeny is offline
post #6 of 16 (permalink) Old 01-22-2019, 09:18 AM
Road dawg's Avatar
I used stainless steel cable from home Depot, put a little metal loop on one end real easy to slide the wires thru with some WD40, was better than a small bead chain from an old set if blinds, learn something new everyday.
Road dawg is offline
post #7 of 16 (permalink) Old 01-22-2019, 11:39 AM
craigffb's Avatar
Dang, you cats are fancy. I always just pull the wires with a shoe string. Drop it through first with a nut on the end.
craigffb is offline
post #8 of 16 (permalink) Old 01-22-2019, 11:46 AM
BB Bomber's Avatar
I just used butchers string. Worked fine.
Check out JSR Customs along your search. I had a set custom made for half the the price of what some charge for their regular production bars.
Do the bars yourself, easy enough, just gotta be patient. Also recommend changing the riser bushings as well to poly ones since you're going to have it apart any way. Also easy to do. I got Arlen Ness ones for like $10 or so. Makes the bars more solid.
BB Bomber is offline
post #9 of 16 (permalink) Old 01-22-2019, 01:33 PM
Road dawg's Avatar
Patience is key +1 on that I did mine a couple of weeks ago. The quality of the bars was excellent, Wild 1 Reaper bars 14 inch but there is a considerable amount of work on pre- Rushmore roadglides, I'm the end well worth it, very comfortable, and looks killer.
File Type: jpg IMG_20190119_132505269_HDR_1548185580603.jpg (2.97 MB, 68 views)
post #10 of 16 (permalink) Old 01-26-2019, 02:19 PM
Bevis's Avatar
I used 550 paracord. Used a bit of dawn dish soap and the wires slid right thru.
dbeny likes this.
Bevis is offline
Yaffe Monkey drag bars connector Controls & Handlebars 18 04-30-2019 01:52 AM
Bars on '10 fltrx comparing a couple - thoughts? kyle31490 Controls & Handlebars 12 02-16-2014 08:49 AM
My f#@%&! THOUSAND dollar bars are done RGCBandit Controls & Handlebars 48 02-27-2013 02:14 AM
Anyone switch from the Heritage bars to Yaffe 10" or 12" Monkey Bars? modot66 Controls & Handlebars 2 09-11-2012 02:35 PM
Road 6 Custom RG bars Hotroadking Controls & Handlebars 6 03-19-2011 10:47 AM
