Handlebar Install ??'s - Road Glide Forums
 10Likes
post #1 of 13 (permalink) Old 01-30-2019, 09:03 AM Thread Starter
I know it might be personal preference, but this really isn't addressed in all of the youtube videos that I've watched up to this point. For those of you that have changed out your bars, are you torquing all of the bolts to spec and applying any loc-tite or are you simply tightening the bolts by hand, making sure you don't He-man the bolts?
I know I need to pick up a service manual here at some point, but can anyone supply the torque specs they use for the riser bolts and the controls/levers?
It's currently -23 out, so I will NOT be making it out to throw these bars on today, however it's suppose to be back in the 50's - 60's by the weekend, so I'm looking to get this lined out for a quick install and get some photos for you all!!
RoadglideinMO is offline
post #2 of 13 (permalink) Old 01-30-2019, 09:11 AM
BB Bomber's Avatar
Torqued to specs.
RoadglideinMO likes this.
BB Bomber is offline
post #3 of 13 (permalink) Old 01-30-2019, 09:29 AM
Road dawg's Avatar
I always torque bars to spec, and not with a harbor freight POS wrench either, a good name brand , of for me Snap on because I use them at work, I torque everything , don't take chances not on two wheels. There's a reason for these specs. I loctite alot of fastners but never did the handlebars.
RGKen and RoadglideinMO like this.
Road dawg is offline
post #4 of 13 (permalink) Old 01-30-2019, 09:41 AM
craigffb's Avatar
Torque the top clamp bolts to spec and in the correct sequence. So they hold, you don't round out the head, and you don't snap a fastener. I've never put lock tight on them either. Oh and I use a "harbor freight POS wrench". I use them for everything. Never had an issue with them.
AJsix and RoadglideinMO like this.
craigffb is offline
post #5 of 13 (permalink) Old 01-30-2019, 10:00 AM Thread Starter
Anyone want to share the sequence of torquing the clamp down and what ft. lbs. of torque to use? From what I can find, it should be done in a criss-cross pattern and around 20 lbs of torque?
Man, there should really be a sticky post for this with the popularity growing on DYI handlebar projects!!
post #6 of 13 (permalink) Old 01-30-2019, 10:25 AM
craigffb's Avatar
I can't remember off the top of my head. But I can tell you when I get home. But I think it's done in two steps and you do the top two first then the bottom two, then the top two to final torque, and then the bottom two. Like I said I think that's what it is but don't quote me on it.
craigffb is offline
post #7 of 13 (permalink) Old 01-30-2019, 11:16 AM
Stoic Joker's Avatar
I just tighten mine, and I've never had an issue.
I snug the fronts first and then tighten the back two (leftover habit from my Jap days).
Scarlet Red 2010 Road Glide Custom named Trixie - She's a flashy little minx..
Basic black 1981 Tour Glide Classic named Alice - She's a sleeper project.
Stoic Joker is offline
post #8 of 13 (permalink) Old 01-30-2019, 11:27 AM
BH#103's Avatar
I'm not in front of my manual right now but it should be to tighten the top bolts until the front of the top clamp touches the bottom clamp, then torque the bottom bolts to 20 ft/lbs then back to the top bolts for 20 ft/lbs. Don't quote me as I'm going off memory. I'll recheck later when I look in my manual to correct any of my mistakes.
"SLIVER"
BH#103 is offline
post #9 of 13 (permalink) Old 01-30-2019, 12:45 PM
Road dawg's Avatar
Glad it works for you, my buddy snapped off bolts on his scoot after using a harbor freight torque wrench I told him to spend a little more and invest in better tools, I can't see paying close to 20k for a Harley and using a sub- par cheap tool on it, just my opinion. But after 30yrs of being a Automotive tech and also wrenching on motorcycles I think I speak with knowledge.
post #10 of 13 (permalink) Old 01-30-2019, 12:50 PM
Road dawg's Avatar
When I tightened mine I did a criss cross pattern, I torqued them evenlly, I know the manual tells you to tighten the top till they touch, but as advice from by a tech at my locks Indy shop I did both sides even.
Help! Electrical Issue following handlebar install Joe.stevens101 Controls & Handlebars 5 08-31-2015 09:06 AM
Daymaker Light Install - Install Problem - And Resolution Martin Lighting 22 06-06-2013 07:57 PM
HD Audio iPod Interface Install - 2011 RGC wachuko Do-IT-Yourself 26 12-31-2012 07:30 PM
In the middle of handlebar install....have a couple ?'s leeinmemphis Controls & Handlebars 7 07-28-2011 12:47 AM
UPDATE my 5x7 Hogtunes speaker and amp install SKULLZ Aftermarket Accessories 8 04-06-2010 09:45 PM
