2014 RG wont start after alarm is disarmed - Road Glide Forums
 2Likes
  • 1 Post By texasnurse
  • 1 Post By ammacdo
post #1 of 7 (permalink) Old 03-08-2019, 09:30 PM Thread Starter
Mort1962's Avatar
Send a message via Skype™ to Mort1962
The starter switch is non responsive after the security system is deactivated. It will start only if the main fuse is removed and then reinserted. it will run and restart as long as the security system does not arm. If it arms I have to remove and replace the main fuse to start it.
Anyone of you experience this before?
Mort1962 is offline
post #2 of 7 (permalink) Old 03-08-2019, 09:33 PM
texasnurse's Avatar
Replace key fob batteries
rider17 likes this.
texasnurse is offline
post #3 of 7 (permalink) Old 03-08-2019, 09:42 PM Thread Starter
Mort1962's Avatar
It cant be that because I eliminated the key fob by disarming security via the pin code....
Mort1962 is offline
post #4 of 7 (permalink) Old 03-09-2019, 04:25 AM
ammacdo's Avatar
I second replacing the key fob batteries. I found I needed to replace the batteries once a year on my 2008, even happened to me on a ride once but thankfully I was close to a Walmart. Grabbed a new battery and bike started right up. I keep spares with me now.
Sent from my Pixel 2 XL using Tapatalk
madmat likes this.
2018 Road Glide Ultra in Silver Fortune and Black Tempest
ammacdo is offline
post #5 of 7 (permalink) Old 03-11-2019, 11:53 PM Thread Starter
Mort1962's Avatar
Thanks guys but after the fob battery swap the problem persists.....Does anyone know the order of operations for the security system arming disarming and the intended systems functionality?
Mort1962 is offline
post #6 of 7 (permalink) Old 03-12-2019, 03:14 AM
ammacdo's Avatar
Before I knew that I needed to change the fob batteries out once a year I had a problem getting my bike started after work one day. The lights flashed and the starter did not turn over the motor. I tried the code but couldn't figure out how to enter it lol that's what I get for not practicing in my garage. I ended up taking the seat off and unplugging the security module from the harness, and plugging it back in. Essentially I power cycled the security system and that did the trick, but the next time I tried to ride after that it still wouldn't start and replacing the fob batteries was the ultimate fix.
I added the security system to my 2008 so I knew where the new module was located under the seat, not sure where it is on the newer bikes though. I traded in my 2008 on a 2018 in December and the new bike has been in storage since I bought it.
I don't know if entering the code would have worked in my situation I mentioned above, but resetting the alarm module is still work a try. If that doesn't work you might have to call the dealer.
ammacdo is offline
post #7 of 7 (permalink) Old 03-15-2019, 03:31 AM Thread Starter
Mort1962's Avatar
Ok guys...I got some diagnostic gear and here are the faults that the software pulled from the bike.....
Fault number: B1123
HFSM left turn lamp (Hands free security module)
Short circuit to ground
Intermittent fault
Historic fault
Fault number: B1131
Alarm
Output Shorted to Ground
Permanent fault
Current fault
Fault number: U1300
Serial data bus
Permanent fault
Current fault
Im thinking about taking it to an Auto electric shop so that they could help locate the shorts......I believe that would be the most expeditious route...what do you guys think???
Mort1962 is offline
I want a remote start and remote control over my air ride? dshudson *General Road Glide Discussions/Pictures 17 08-30-2017 02:26 PM
Initial Sputtering on Start Up After Auto Tuning w PV JDisMe ECM/Fuel Management systems 13 06-28-2017 02:07 PM
Cold start, erratic idle. Tmap, tps? ironmike666 Intake and Exhaust 7 04-23-2016 10:43 PM
Problem with Radio Shack alarm sanders Do-IT-Yourself 7 09-24-2011 02:30 PM
Disable Neutral Start - 2008 RG Trikerjon *General Road Glide Discussions/Pictures 7 05-28-2011 12:19 PM
