2019 road glide handlebar upgrade - Road Glide Forums
 3Likes
  • 1 Post By bosshogg123
  • 2 Post By BH#103
post #1 of 9 (permalink) Old 03-21-2019, 07:19 AM Thread Starter
Good morning,
I am about half way through a handlebar upgrade on a new bike.
Installing a set of factory 47 bars.
I have watched their video several times and I see them taking apart a "square" 6 pin connection.
They do this in order to be able to more easily pull the wire through the bars.
Here -
About 3:40 in to the vid.
I have a question for someone that has done a new bike, did you need to do this?
When I compare the connections that I need to pull through I don't have this same square one to deal with, they are all smaller.
I have a feeling that HD may have improved in this area and made the factory wire connections smaller thus removing one step in the process of handlebar upgrades.
All opinions welcome, sorry I don't know how to post pictures.
beerhunter is offline
post #2 of 9 (permalink) Old 03-21-2019, 07:48 AM
bosshogg123's Avatar
Starting in 2017, the TBW connector was changed to a much smaller connector that eliminates the need to de-pin the connector to fit through the bars; definitely speeds up bar change outs!
madmat likes this.
bosshogg123 is offline
post #3 of 9 (permalink) Old 03-21-2019, 07:55 AM
BH#103's Avatar
2016^^^^^it changed
madmat and Bevis like this.
"SLIVER"
BH#103 is offline
post #4 of 9 (permalink) Old 03-21-2019, 08:04 AM Thread Starter
Ok, thanks for the info. the factory 47 video is a little misleading then.
Sounds good.
post #5 of 9 (permalink) Old 03-21-2019, 08:16 AM
Sounds good.
Also for your info, I believe it was in 2015 on the Road Glides(not sure on other touring bikes), Harley extended the throttle by wire length. When I did my 18, I measured the stock throttle by wire at the point it exited the bottom of the bars and there was 18Ē of wiring from that point. Plenty of length for many bar changes.
FLTRXS20 is offline
post #6 of 9 (permalink) Old 03-22-2019, 07:05 AM Thread Starter
Are there two seperate connections that are not in use on the 2019's?
I have reconnected everything that I see and I am left with 2 that do not match.
Just wanted to check before I finish up.
Thanks for any info.
post #7 of 9 (permalink) Old 03-22-2019, 07:24 AM
madmat's Avatar
Post some pics of the connectors
18 RGS Bonneville Salt Pearl
madmat is offline
post #8 of 9 (permalink) Old 03-22-2019, 07:33 AM Thread Starter
I believe they are both the smaller square ones maybe a 2 pin connection?
One is on the bike, one is from the bar wiring.
Sorry, don't have pics. right now.
Pretty sure the one coming from the right side is for heated grips.
post #9 of 9 (permalink) Old 03-22-2019, 05:35 PM
BH#103's Avatar
Should be for heated grips. The right side heated grip would get plugged directly into the tbw assembly end so there will be an unused connector on the tbw harness.
"SLIVER"
BH#103 is offline
First time: Road Glide Special 2019 Rwhite1357 New Members Welcome Area 27 01-21-2019 11:18 AM
SCOOP: 2015 Harley-Davidson Road Glide Spied VS Jeff Home Page News 9 09-10-2015 12:54 PM
2015 Harley-Davidson Road Glide First-Ride Review VS Jeff Home Page News 0 07-22-2015 12:14 PM
The Ultimate Road Glide Handlebar sdlakerfan79 *General Road Glide Discussions/Pictures 25 07-15-2013 01:46 PM
Traded my 2006 Street Glide for 2013 Road Glide RedLiner *General Road Glide Discussions/Pictures 19 10-16-2012 01:05 PM
