Riser bolts - Road Glide Forums
post #1 of 5 (permalink) Old 03-30-2019, 11:21 AM Thread Starter
Bfiorini's Avatar
Riser bolts
Hey guys. I’m changing out the handlebars and putting in new riser bolts. I’ve been reading that with the new riser bushings that you should use 2 1/4” long grade 8 bolts. Well every damn place is closed until Monday and all I have is 2 1/2” long bolts. Is it ok if I just take a hacksaw and cut a 1/4” off??? Or should I just wait until Monday and buy the correct bolts. Thanks
Bfiorini is offline
post #2 of 5 (permalink) Old 03-30-2019, 11:24 AM Thread Starter
Bfiorini's Avatar
Oh. And should I use lock washers with the washers Arlen ness poly risers come with??
Bfiorini is offline
post #3 of 5 (permalink) Old 03-30-2019, 03:34 PM
BB Bomber's Avatar
I don't see a problem with cutting them shorter. As long as they're not poking through the risers so the bars won't clamp properly. Dab a little blue locktight on those bottom bolts too.
I don't remember my ness bushing coming with lock washers, but if they did, why not?
BB Bomber is offline
post #4 of 5 (permalink) Old 03-31-2019, 10:47 AM Thread Starter
Bfiorini's Avatar
Ya the ness riser bushings don’t come with lock washers. I was gonna put them on for added security, but I didn’t know if that would negatively affect anything.
Bfiorini is offline
post #5 of 5 (permalink) Old 04-01-2019, 04:39 PM
wevsspot's Avatar
If you add lock washers there's a good chance that the forks won't turn lock to lock. There isn't enough clearance down there (at least on the 2015 and 2018 I did). It's OK to trim the bolts (again exactly what I had to do). You have room for the cup washer and the bolt head. Nothing more in my personal experience.
wevsspot is offline
Size of Riser Bolts djkusiak Controls & Handlebars 2 06-13-2017 04:08 PM
2013 CVO - Handlebars & Riser Question BigThunder Controls & Handlebars 0 09-20-2014 03:38 PM
accessing riser bolts THEMASTERDESTROYER Controls & Handlebars 12 01-30-2014 08:40 PM
Installed Chrome bolts in the Rocker Covers ironmark *General Road Glide Discussions/Pictures 9 04-05-2012 12:19 AM
bolts in rear hub Sancho *General Road Glide Discussions/Pictures 3 01-12-2011 06:50 AM
