Adjustable Levers - Road Glide Forums
  • 1 Post By KansasFLTRU
post #1 of 5 (permalink) Old 05-07-2019, 10:16 AM Thread Starter
jlmowry's Avatar
Adjustable Levers
I'm looking at adjustable levers and hoping to get some recommendations here. I'm aware of the RSD Regulator levers as well as the Oberons. Any others out there I should consider? What do you all recommend?
Thanks,
Jim
jlmowry is offline
post #2 of 5 (permalink) Old 05-07-2019, 12:58 PM
KansasFLTRU's Avatar
Iíve had the Oberons on my 2017 RGU for about a year, clutch and brake. My observations are this:
1. They are expensive. Way overpriced but I thought they would be a real solution so I ordered them.
2. If I knew about the friction zone fix for the 2019 models, I would have had that done instead of going this route.
3. Most people say they are uncomfortable and I tend to agree, but to say they are bothersome to me would not be true.
4. When I took my bike in for the clutch recall, the tech said that the clutch was not fully disengaging when I had the adjustment set at 2 or 3. So now I run it at 4 to be sure I am disengaging. Thatís an improvement, but a fix for me would have been 2 or 3.
Iím still undecided about taking the clutch apart to install that thicker ring which moves the friction zone more to the middle. Thatís why I bought the Oberons, to improve my slow speed maneuvering, but I have to admit that I have really enjoyed having the engagement clear out to the end for shifting. It makes a shift more of a ďflickĒ, and I can go through the gears almost sounding like an automatic transmission.
LS GLIDE likes this.
Thereís a place that I travel, when I want to roam, and nobody knows it but me.
2017 Vivid Black Road Glide Ultra
KansasFLTRU is offline
post #3 of 5 (permalink) Old 05-07-2019, 05:45 PM
LS GLIDE's Avatar
Rick @ Softbrake has 1" reduced levers. They are a swap for your originals, I didn't look into it completely the info just came with my extended her brake lever
'19 RGS
LS GLIDE is offline
post #4 of 5 (permalink) Old 05-07-2019, 06:15 PM
smitty901's Avatar
2017 and newer you have to go with Oberons, RSD Regulator will not fit. I had the RSD Regulator on my 2016 and liked them , the adjustment system is not as good as the Oberons but they work.
smitty901 is offline
post #5 of 5 (permalink) Old 05-08-2019, 03:49 PM Thread Starter
jlmowry's Avatar
Thanks for the responses. I talked the good folks at Revzilla into a discount on the Regulators which should be here Friday. They are easier on the wallet than the Oberons. Hopefully installed over the weekend.
jlmowry is offline
2017 adjustable levers smitty901 Aftermarket Accessories 30 02-07-2018 11:12 AM
Best adjustable levers for 2015? RonC26 Aftermarket Accessories 2 08-08-2017 03:49 PM
2017 adjustable levers, reduced reach smitty901 Controls & Handlebars 57 06-29-2017 11:56 AM
Anyone interested in Oberon Adjustable levers? HogPro *General Road Glide Discussions/Pictures 14 10-14-2015 04:16 AM
