Recommendations for 14" apes 2017 RGS - Road Glide Forums
 11Likes
post #1 of 16 (permalink) Old 08-15-2019, 01:46 PM Thread Starter
Hello all,
This is my first post. I'm glad to be part of the group.
I am looking to add tall apes (no higher than 14") to my 2017 RGS, and I am looking for recommendations on bars that do not require modifications to the bike or require cabling/wiring work.
I have looked at the Chizeled 14" apes from HD, but the dealership said I needed brake/clutch cabling (not a big fan of bleeding ABS systems).
I also looked at KST Kustom bars, but they require knocking down the index pin in the bar clamp and grinding down tabs on the control clamps.
I was looking at Factory47, and their 14" apes say I don't need to mod the cables, but the pin will have to be knocked down (same bar for CVO/Ultra as the Road Glide).
Any suggestions/experiences that you could share would be greatly appreciated!
Wvchilling is offline
post #2 of 16 (permalink) Old 08-15-2019, 03:26 PM
Spazz's Avatar
Factory 47s... 1.5" bars are way better looking and easier to run wires... 2 hours and I was done...I run my bars inline with forks and didnt have to remove the pin from the riser clamp.
Sent from my SM-G975U using Tapatalk
Mike U likes this.
RENO BAGGER AUDIO
Spazz is offline
post #3 of 16 (permalink) Old 08-15-2019, 03:42 PM
RFG7680's Avatar
Yep. Another vote for Factory 47s. And tapping the pin in takes about 3 taps with a 3/8s ratchet. And like Spazz said. Run your bars online with the forks.
Mike U likes this.
RFG7680 is online now
post #4 of 16 (permalink) Old 08-15-2019, 04:49 PM
madmat's Avatar
Plus one on the above ^^^^^^. The last set I put on I bought the 12" extensions from guerilla wires on the f47 sight. Not needed but made for a little cleaner install $30.00, plug n play.
Good luck, let us know what you decide.
Welcome to the forum from Mass
Mike U likes this.
18 RGS Bonneville Salt Pearl
madmat is offline
post #5 of 16 (permalink) Old 08-15-2019, 05:55 PM
Welcome and good luck in your bar search.
madmat likes this.
FLTRXS18 is offline
post #6 of 16 (permalink) Old 08-15-2019, 09:32 PM
Taz_FL's Avatar
On my last 15 roadglide and my current 17 roadglide ultra I installed the KST Kustoms 14" Outlaw bars. I really like themended up not needing any wire extensions at all as well as no clutch/brake lines. Good looking bars and for me they are very comfortable.
madmat and kiwidave like this.
Taz_FL is offline
post #7 of 16 (permalink) Old 08-16-2019, 10:24 AM
GMONEY's Avatar
Location: LexVegas, KY...home of fast wimmen & beautiful horses
Carlini Design...the BEST bars on the planet. Bar none. Of course, Iím biased and run Menace apes on my CVOs.
http://www.carlinidesign.com/Ape-Hangers/
For all your cables & lines...holler at the guru Johnny Vaughn at www.HDbikeparts.com
madmat and Swomack like this.
\_/ Chicks Dig Ape Hangers \_/
IronButt Assoc. #27301
Combat Vets Motorcycle Assc. (KY 1-1 original chapter)
GMONEY is online now
post #8 of 16 (permalink) Old 08-16-2019, 06:33 PM
Just installed 12in Factory 47 signatures 2 days ago. Agreed with above post that the 1.5in bars are much easier to run wires. Little rag with WD40 slicking up the heat wrap helps tremendously. Plus the beefier bars look more natural with the bike/forks imo. I’m very pleased. They say 14in will reach but it will be tight. The clutch is zip tied in a couple places behind the wiring under the riser. Cut those and it will give you more to work with. Break side was no problem. Pretty easy installation and there are videos via their website as well as YouTube diy vids. F47 also provides a more adjustable safety pin hole in the bars that allows you to adjust them a bit more to your liking. Not a ton obviously but enough to matter. I found that lined up with the forks was not only better looking but perfect distance for comfort.
madmat and RFG7680 like this.
abeale3 is offline
post #9 of 16 (permalink) Old 08-16-2019, 11:51 PM
Jersey Drew's Avatar
I found the vindicated/factory 47 bars to be too wide and still too much pullback. I got a set of road 6 customs 13 inch bars and love em. Donít be afraid to pull the pin on the riser and most bars you donít have to grind off the pins on the clamp.
'16 Road Glide Special
Jersey Drew is offline
post #10 of 16 (permalink) Old 08-17-2019, 06:02 AM
Riderduke's Avatar
Originally Posted by Jersey Drew View Post
I found the vindicated/factory 47 bars to be too wide and still too much pullback. I got a set of road 6 customs 13 inch bars and love em. Don’t be afraid to pull the pin on the riser and most bars you don’t have to grind off the pins on the clamp.
+1... Love my Road 6 Customs. My Mustang seat also sets me down and back about 1.5" so its like having 14" bars
2017 Road Glide Ultra
I don't Have a Bucket-List... I have a Bike-it list
Riderduke is offline
Tags
ape hangers , cables , chrome , tall
