Clutch Cable Rubbing on Gauge Nacelle - Road Glide Forums
post #1 of 8 (permalink) Old 12-21-2010, 09:07 AM Thread Starter
dirtbag's Avatar
The clutch cable on my bike rubs on the gauge nacelle and I'm sure its a common problem, may already be a thread for it, tried searching...
Theres this:
http://www.jpcycles.com/product/5000015
I just got my fairing painted and don't want to destroy it.
Any suggestions? Tried and tested ideas? The stock HD strap/clamp isnt gonna cut it
2010 FLTRX - THE RED DRAGON
KCCO - CHIVE ON!
dirtbag is offline
post #2 of 8 (permalink) Old 12-26-2010, 01:18 AM
I fixed mine with a tie wrap on the inside that was about 18 months ago as a quick fix still holding in place
dgb road is offline
post #3 of 8 (permalink) Old 01-03-2011, 08:14 PM
My neighbor just replaced the HD retainer with a black plastic P-clip from the local Ace hardware store. I think it was a plumbing part....
2010 roadglide custom, 10" monkeys, 8" windvest, 7.25 J&M, 200w bazooka, Iron Aces mount, Danny Gray Air Hawk, Vance & Hines Big Radius, TTS, SE forced air, SE 255 cams, pushrods, roller rockers, this and that...
flatblackbastard is offline
post #4 of 8 (permalink) Old 01-07-2011, 08:41 AM Thread Starter
dirtbag's Avatar
i ended up buying the part listed above. Will post info/pics on how well it works. looked around in Home Depot and Lowes and didnt find anything that really hit the spot as far as inexpensive repairs. I have to look at it when I ride and it would bother me if it didn't turn out like I wanted. Thank you for the posts and suggestions, I was hoping another company made something similar, but not so flashy or expensive, but if it works, it will save my paint!
KCCO - CHIVE ON!
dirtbag is offline
post #5 of 8 (permalink) Old 01-07-2011, 08:43 AM Thread Starter
dirtbag's Avatar
Come to think of it, I just looked at the pics above, and I saw that part at Lowes and I wasn't sure if it would work... seeing it now, it does!
KCCO - CHIVE ON!
dirtbag is offline
post #6 of 8 (permalink) Old 04-30-2011, 04:32 PM
HD_Shock's Avatar
Is it this piece?
http://www.pro-one.com/Speedo_Cable_...t_p/500720.htm
Looks close but they call it a speedo cable guide. Even if not, it looks like it'd work.
Edit: Never mind - I see it's the same part you posted initially from JP.
-phil
2011 FLTRX 103
HD_Shock is offline
post #7 of 8 (permalink) Old 04-30-2011, 06:22 PM Thread Starter
dirtbag's Avatar
Yup, unfortunately I couldn't find it for less than $27, plus shipping. But it beats getting things repainted.
KCCO - CHIVE ON!
dirtbag is offline
post #8 of 8 (permalink) Old 07-19-2012, 08:39 PM Thread Starter
dirtbag's Avatar
Just an update, I located it lower on the frame after rerouting the clutch cable for the taller bars.
KCCO - CHIVE ON!
dirtbag is offline
Changed clutch cable to +6 cable...clutch does not appear to engage backwaterdogs Troubleshooting for Road Glides 4 05-20-2017 08:09 PM
Need Help-Clutch Cable Lever Change-Tight Cable SNemet Controls & Handlebars 6 04-28-2016 05:42 PM
Gauge cluster nacelle removal question? tcon287 Tech Area 10 04-07-2015 12:31 PM
inner fairing,Nacelle,gauge cluster trim pat123 Parts for Sale 7 10-01-2013 07:34 PM
Clutch cable clip on side of gauge housing GizmoGlide *General Road Glide Discussions/Pictures 8 03-26-2010 12:00 PM
