Stupid easy way to do handlebar wiring - Road Glide Forums
 7Likes
  • 5 Post By Stoic Joker
  • 1 Post By msquad
  • 1 Post By The Volusianator
post #1 of 8 (permalink) Old 11-10-2019, 02:24 PM Thread Starter
Stoic Joker's Avatar
So I ran into a situation where I had to rerun the wiring through a set of T-bars while they were still mounted on the bike.
Impossible right? No.
Kite string and a vacuum cleaner made it easy as hell. Put kite string in the top hole, put the vacuum cleaner's attachment hose on the bottom hole ... And hang onto the top because the string will be where you want it before you can blink. Then pull through as usual..
Just thought I would share that option for the next poor sad bastard that might find themselves in the same situation I did.
Scarlet Red 2010 Road Glide Custom named Trixie - She's a flashy little minx..
Basic black 1981 Tour Glide Classic named Alice - She's a sleeper project.
Stoic Joker is online now
post #2 of 8 (permalink) Old 11-10-2019, 03:43 PM
Zedbra's Avatar
Yup, that's how I did it when I ran the guide wires in my bars.
2008 FLTRU w/110" SE TC
Zedbra is online now
post #3 of 8 (permalink) Old 11-10-2019, 04:51 PM
I do my bars with Weedwhacker string.
Spazz likes this.
2017 Hard Candy Hot Rod Red Flake M8 FLTRXS Road Glide Special. Stage III with *lots* of other goodies.
msquad is offline
post #4 of 8 (permalink) Old 11-10-2019, 05:26 PM
UltraWalt's Avatar
I use the pull chain from like a ceiling fan.
2019 Roadglide Ultra
UltraWalt is offline
post #5 of 8 (permalink) Old 11-10-2019, 06:14 PM
+1
Paul110 is offline
post #6 of 8 (permalink) Old 11-10-2019, 08:56 PM
The Volusianator's Avatar
Too easy to break that stuff. You know the Chinese finger trap stuff? I got a long piece of that, ran string through my bars, pulled the finger trap through with the string, put the wires in the finger trap and pulled back out, wires stay in the finger trap so they're protected from rubbing inside the bars and it made for an easy fish through. KST bars
Wade
pit1600 likes this.
The Volusianator is offline
post #7 of 8 (permalink) Old 11-11-2019, 04:19 AM
texasnurse's Avatar
Nylon string. Leave a loose end at both end cap and switch housing hole , then you can pull twist grip at same time as switch housing.
P.S. Pros use compressed air!
texasnurse is offline
post #8 of 8 (permalink) Old 11-17-2019, 03:54 AM
pit1600's Avatar
Wade
Thanks for the tip. I will try it for next bar change, buddys always come home for that stuff. We use chains but this way sounds good.
pit1600 is offline
