handle bags seem soft - Road Glide Forums
post #1 of 3 (permalink) Old 06-20-2013, 02:59 PM Thread Starter
The bars on my road glide are tight in the cradle but when i ride it they seem to be a little spongy when riding. I know that they are rubber mounted or is it just my mind. Or should i be looking into it more.
Thanks for any info
nugz
nugzz is offline
post #2 of 3 (permalink) Old 06-20-2013, 03:13 PM
RhinoHD's Avatar
Thanks for any info
nugz
Do you have other then stock bars? If so did you replace the rubber riser bushings with Poly bushings? Rubber bushings will wear out faster with taller bars. The poly bushings are stiffer...
Either way check the bolts at the bottom (under side) of the riser. I just added APES and the poly bushings needed to be tightened after 200 miles. Mine must of seated more since the install...
Hope this helps.
Life is good but it's not easy!
RhinoHD is offline
post #3 of 3 (permalink) Old 06-20-2013, 03:36 PM Thread Starter
rhino hd were do you find the heads on the bottom bolts.
Thanks
nugz
nugzz is offline
Doesn't seem right. Ranger75 Suspensions 7 01-14-2013 05:47 AM
This may seem wierd, but... dbell66253 Paint & Bodywork Section 21 01-08-2013 09:16 AM
Can't seem to get photo to appear in my signature. fatboyO Forum Help Desk (Post Forum Issues Here) 1 05-09-2011 05:13 PM
Always seem to be cleaning my bike METIME *General Road Glide Discussions/Pictures 32 11-16-2010 03:28 PM
