Ok.. Now I am stuck (Handle Bar internal wiring) - Road Glide Forums
post #1 of 17 (permalink) Old 01-04-2011, 11:33 AM Thread Starter
Well after months of research I decided on doing a handle bar swap as a DIY project. I studied the manual and followed the threads. Everything was going great last night. I had the faring removed, wires run (a pain but 4 hours later and complete) with all existing wires to include TBW. I follow everyone advice and used soap and use a small chain to pull the wires. Well now I have the bars on the bike and now I can not get the deutsch connectors (inner fairing) (left and right controls) back together!!!! The pins are not locking in place and I can get the connector back together. The connectors are easy to take apart and a pain to reassemble. I can get these pins to line up. Does anyone know any tricks or recommendations? I am almost done except for those connectors!!!
Stats:
Bike: 2010 Road glide Custom
Bars: Wild 1s Outlaw mini apes (12 inch)
Wires: All Stock wires
Re-routed clutch
help!!!
habu_sake is offline
post #2 of 17 (permalink) Old 01-04-2011, 12:31 PM
harley75's Avatar
You have to play around with the connectors. There is a certain way that they go in and they will lock. I stuck mine all the way through, then twisted it around and pulled them back into the bracket to seat the connectors. The key is to get them all in and hurry up and push the plate back in the connector around the pins before they move. That what locks them in and lines them up. Its just frustrating but you will eventually get it.
75 Superglide
04 Texas Chopper
10 RGC
harley75 is offline
post #3 of 17 (permalink) Old 01-04-2011, 01:46 PM Thread Starter
Thanks. I will give it a try tonight/
post #4 of 17 (permalink) Old 01-04-2011, 04:21 PM
hotrodad's Avatar
hmmm the connectors were easy except for the one pin I broke. I almost started putting the pins in backwards at first though. Make sure you got them the right way they should just almost fall into place. Don't hurry....no need.
I had problems routing the clutch cable however.
cheers!
2005 FLTRi
Black Pearl
Live to Ride ~ Ride to Live
hotrodad is offline
post #5 of 17 (permalink) Old 01-04-2011, 06:09 PM
Justice1's Avatar
Make sure the plate in the connector is pulled up to it's highest position like when you took the pins out. I fought with that for about an hour before I gave up and decided to sleep on it. Went out the next morning, tried inserting them with the plate up, and I was done in about five minutes.
Venor Lupus
Justice1 is offline
post #6 of 17 (permalink) Old 01-04-2011, 06:13 PM
Justice1's Avatar
Oh yeah,
After all the pins are in place, push the plate back down. If I remember correctly, the pins "clicked" into place as you insert them into the connector. (with the plate up)
Venor Lupus
Justice1 is offline
post #7 of 17 (permalink) Old 01-04-2011, 06:21 PM
DAK47's Avatar
Totally agree with walking away sometimes, before frustration and breakage occurs(not just pin connectors) and coming back with a fresh perspective later. Hard lesson for me to learn as a stubborn sob...
Dirk
'12 CVO Dogfish / '03 Gunmetal 103" Roadie
DAK47 is offline
post #8 of 17 (permalink) Old 01-04-2011, 10:22 PM Thread Starter
I can't get them to line up!!! Going to give it a rest for then next day or so. Thanks for the advice.
post #9 of 17 (permalink) Old 01-04-2011, 10:52 PM
molitord's Avatar
Definitely shouldn't be that difficult. They only go in one way and they snap in before you even push the plate back down to lock them in place. Are they going in at all or stopping half way? If they are stopping, the only 2 things I can think of is the plate not being pulled up far enough or they are twisting as you are pushing them in and they aren't staying square. Maybe post a couple of pics and see if anyone can see anything wrong.
molitord is offline
post #10 of 17 (permalink) Old 01-04-2011, 10:53 PM
fltreagle's Avatar
There are little tips on the connectors they have to go in a particular way look and the block and you will see the indent in the blocck, that is the clue on how the pins go in and then when you are done you have to push the lock bar back down. Make sure the lock bar is pulled up to push the pins in. The connector is numbered and check to be sure you have proper placement before pushing the pins in, don't forget to push then thru the rubber weather seal first. The secret is to take your time and get it done right the first time.
fltreagle is offline
Ignition switch Stuck & i mean stuck.... maddmoe Troubleshooting for Road Glides 11 07-08-2016 05:22 AM
handle bar wiring Tatude Controls & Handlebars 3 05-19-2013 07:25 PM
New Paughco apes for FBW and internal wiring 4getNo1 Controls & Handlebars 32 01-20-2011 08:39 AM
Enlarge internal wiring hole gja Controls & Handlebars 7 11-21-2010 08:18 AM
Internal Wiring glovergs Do-IT-Yourself 3 09-08-2010 12:47 PM
