Handlebar Options for CVO Ultra - Road Glide Forums
post #1 of 14 (permalink) Old 06-27-2013, 11:30 AM Thread Starter
Would like to find a handlebar with more pull-back for my 2011 CVO RG Ultra. Not finding anything available from H-D. Everything in the catalog says no hydraulic cluth, no heated handgrips, yada, yada, yada. Anybody have some recommendations? The present pull-back is speced at 6.75".
Jerry
Jerry/MD is offline
post #2 of 14 (permalink) Old 06-27-2013, 11:57 AM
93-331-29psi's Avatar
You're gonna have to go aftermarket to achieve what you are looking to achieve. Lots of good options out there.
Wild1 Chubby (works on my CVO just fine)
BR Bars
Buky bars
The list is endless. Good luck.
93-331-29psi is offline
post #3 of 14 (permalink) Old 06-27-2013, 01:26 PM Thread Starter
BR Bars
Buky bars
Thanks 93-331-29psi. I was looking on the Wild1 website not long after posting. Did you install yourself?
Jerry
Jerry/MD is offline
post #4 of 14 (permalink) Old 06-27-2013, 06:58 PM
I just did a set of sweeper 2+2s and love them and they are less than 80.00 but mines not a CVO
dusturbd is offline
post #5 of 14 (permalink) Old 06-27-2013, 08:08 PM
Road dawg's Avatar
Cycle visions makes a bar that is two inches farther back than stock,it also comes in black thats what im looking at myself goes for about 120.00 im sure u can find it for less.
Road dawg is offline
post #6 of 14 (permalink) Old 06-28-2013, 07:41 AM
Jerry
Yes I did my own install. It wasn't fun, but it wasn't that bad either. Just have to take your time and document where everything goes. I've got a write up that I could point you to should you decide to do your own install. The only advise I can give is don't cut and solder the wires. Removing them from the terminal sockets isn't that hard to do.
post #7 of 14 (permalink) Old 06-30-2013, 09:01 PM Thread Starter
Sounds good. Point me to your write up when you can. I'm a Test Engineer so removing terminals from the connectors is not a problem. Been there...done that.
Jerry
Jerry/MD is offline
post #8 of 14 (permalink) Old 06-30-2013, 09:14 PM
I put the CVO bars on my ride & there sweet. Just loosen the head clamp & pull'em back till ya happy. Save ya $ for something else.
12 RGU Ember Red Sunglow
Heated Hammock seat, CVO bars
Decat, heated grips
billy t is offline
post #9 of 14 (permalink) Old 07-01-2013, 06:01 AM
Easyryder01's Avatar
I sat on an RGU which the fella had the bars changed out to the CVO bars on tour scoot, I've been looking to change my OEM bars to them but after sitting on the bike and feeling and. Seeing them they left me with very little to be desired. I wound up going with the Arlen Ness Mini Apes 10" which are also 1 1/4" thick into he areas nothing is clamped to and I also wound up installing them myself (first time doing this work) , I could have gone either way on the install but never the dealership to do it. Another issue I gave myself since I wanted to do the work myself was I didn't want to change out my cables or get extensions for the wires, turns out I don't need extensions for the wires all the way up to 12" apes but I do have to change the cables and brake line to make a 12" bar fit. I must say I do like the bars very much but they were expensive and more than I wanted to spend, hence doing the job myself. Good luck.
Side view of bike with above mentioned bars.
2017 RGS Velocity Red
Easyryder01 is offline
post #10 of 14 (permalink) Old 07-01-2013, 06:40 PM
smitty's Avatar
Jerry, I have the same bike as you and I put the Wild Ones 612 on it and all of the stock wiring and lines worked fine. It has about 10 inches of pullback with the bars inline with the front forks.
2011 CVO Roadglide/ Jackpot Exhaust/ Powervision/ Madstad 16/Sanchos Wings/ 12inch Wild Ones Outlawz / Traxxion AK20 / Ohlins #6
smitty is offline
2015 handlebar options trifiveshawn Controls & Handlebars 23 09-04-2016 06:59 PM
Handlebar control options for new head unit? Joesquid Audio 17 01-28-2015 07:35 PM
Handlebar radio control options laxinharley Audio 19 01-24-2015 10:54 AM
Handlebar Options Robare Controls & Handlebars 11 07-13-2012 03:03 AM
2011 ultra bars vs CVO ultra bars? Thistlethunder Controls & Handlebars 2 11-04-2011 06:11 PM
