Check engine light - Road Glide Forums
post #1 of 2 (permalink) Old 06-27-2013, 12:06 PM Thread Starter
Check engine light
I installed new apes on my 2011 roadglide. throttle (TBW), switches, lights, & gauges work.
bike runs great, the only problem I have is that the "Check Engine" light remains on. I ran through the DTC's no codes are displayed. Any suggestions?
bigtommy55 is offline
post #2 of 2 (permalink) Old 06-28-2013, 10:25 AM
In most if not all situations where the engine light is on it means that there is a DTC code and the DTC needs to be addressed and cleared. If the engine light stays on then it is an active DTC code, if the engine light stays on for a few minutes then turns off while the bike is running then it is a historic DTC. I would suggest going through the entire DTC process again it may be possible that you left out a section.
Check Engine Light and Battery Light following Jackpot 2-1-2 install PearlBlueUltra Troubleshooting for Road Glides 9 06-15-2014 03:59 PM
Check Engine Light Ran8175 Troubleshooting for Road Glides 0 07-17-2011 01:17 PM
05 Roadglide check engine light camperfan Troubleshooting for Road Glides 8 05-03-2011 07:36 AM
Engine check light keeps coming on 2011 RGC madmatt Road Glide Specific Discussions 11 02-13-2011 11:14 PM
Oil Overfill and Check Engine light Biker Tom Troubleshooting for Road Glides 5 09-15-2010 07:01 AM
