Cable size for 12" oem monkey bars - Road Glide Forums
post #1 of 12 (permalink) Old 01-12-2011, 07:55 PM Thread Starter
pennstater's Avatar
Does anyone know what size brake and clutch cable I would need for 12" oem monkey bars on a 2010 road glide?
pennstater is offline
post #2 of 12 (permalink) Old 01-13-2011, 05:04 AM
Peewee's Avatar
I don't think that you will need new cables or wiring extensions. I did a set of 12" KhromeWerks with no changes. Chainsaw said that stock cables were good for up tp 14" if I remember
"Know Thyself"
Peewee is offline
post #3 of 12 (permalink) Old 01-13-2011, 05:05 AM
Neano62's Avatar
PM Frodoe, he put 12" on his
[/IMG]
Neano62 is offline
post #4 of 12 (permalink) Old 01-13-2011, 09:02 AM
DED HD's Avatar
I put 14" Santees apes(look about the same height as the 12" Monkey bars)
on my 2010 and only got a +4 inch clutch cable so I could route it the same as from the factory.
Dont think you will need any new cables, but if you want to route the clutch cable the same as stock, i recommend getting a +4" cable.
'10 Red Custom:
DED HD is offline
post #5 of 12 (permalink) Old 01-13-2011, 11:17 AM
MassHD's Avatar
Let us know what Frodoe said. I have the 10" in my garage and might go with the 12" if I can eliminate the cables.
2010 Road Glide Denim Black
ABS Cruise Factory Security, Black D&D 2 into 1
Firecap's Arc Amp 125.2, 4- Hertz 6 1/2" Speakers
PYO Bars, CVO Rear Fender, KW Wrapper Front Fender
"Burn Rubber Not Your Soul"
MassHD is offline
post #6 of 12 (permalink) Old 01-13-2011, 11:30 AM
DED HD's Avatar
You guys can do it!
Slowglide has the same bars as I do, Santees 14" apes, and he used the stock clutch and brake line. He just rerouted the clutch behind the triple tree instead of in the factory mounting location attached to the tach and Speedo gauge Cluster.
I wanted mine in the factory location and didnt want the clutch to pull when turning the bars etc. so just went with a +4" clutch cable, just to be safe.
All stock wiring harnesses are good to probably at least 15" apes.
It can be done!
'10 Red Custom:
DED HD is offline
post #7 of 12 (permalink) Old 01-13-2011, 11:48 AM
DED HD's Avatar
From Frodoe post:
"Yesterday I pulled my ride apart, did some wire work I wanted and broke her down for the 12" Monkey bar install.
Day 2 I started the wire pull. Now pay close attention, after purchasing wire extention kit from yaffie. I noticed no TBW kit, called Paul and in his own arrogant way let me know it was not needed, I asked why he sold it to me? Well dude was right I pulled all the wires using all the stock covers, had my wife help keep pressure on wires as I fished, took a few hours with some WD and KY on right, dry for left. Reroughted clutch and brake line. To see how it handles without extending. I'll keep ya up to date. Now remember I'm a disablied dude with a bad back and bumb legs. If I can do it Anyone can. Oh yea, did I mention I got anger issues? Well didn't have to lose my cool. Merry Christmas all and God Bless you all, your bro Frodoe"
Also from Frodoe"You do not need to extend your wires, You can use your Stock wrap. You can keep clutch and brake line Just take clutch from center of forks to side, for your brake line cut the zip tie and let it run freely. "
And from NCBeast "Paul (Yaffe) has told me several time through email that the stock wires and cables are long enough to go up to 12"
hope that helps guys. i
'10 Red Custom:
DED HD is offline
post #8 of 12 (permalink) Old 01-13-2011, 12:10 PM
Arrow You don't need um
I ran my clutch between the front down tubes and cut the zip ties, I also twisted the brake and now it stays along side the bottom of the bar on it's own and looks custom with no ties. The clutch will rub your speedo housing but only jogging around to turn the bike around (Sharp) turns in your shop. other than that it's fine when you ride, and you don't have all that extra cable to zip tie. That kind of defets the purpose of the looks when it comes to the bars.
Oh yah I have the cables sitting in a box, so if I really did need them I'd of put them on when I had my ride apart.
Frodoe is offline
post #9 of 12 (permalink) Old 01-15-2011, 08:06 AM
MassHD's Avatar
Cool thanks. I'm waiting for the Dr. to give me a ETA on a set of black 12". Looks like I'll have a set of new black 10"s for sale soon.
MassHD is offline
post #10 of 12 (permalink) Old 01-15-2011, 08:58 AM Thread Starter
pennstater's Avatar
Paul had them in stock a few days ago.
12" Monkey Bars Clutch Cable issue??? DOCSGT Controls & Handlebars 2 02-22-2014 06:04 PM
Paul Yaffe OEM Monkey Bars v. Monkey Bagger Bars Fahred Controls & Handlebars 14 08-27-2013 09:39 AM
12" Monkey Bars with 12" WindVest Shield? Tek74 Controls & Handlebars 3 02-13-2012 07:50 PM
10" or 12" OEM Monkey Bars for someone 5'5" bagger68 Controls & Handlebars 7 01-09-2012 12:05 PM
What size clutch cable with 12" monkey bars pennstater Controls & Handlebars 5 02-22-2011 05:33 PM
