Connectors dont snap back together - Road Glide Forums
post #1 of 9 (permalink) Old 07-03-2013, 09:03 PM Thread Starter
Did the internal wiring for handlebar took molex apart now the connectors wont snap back together. cant get the pin alignment/holder to set back in housing all the way.
Help
cmetal is offline
post #2 of 9 (permalink) Old 07-03-2013, 09:10 PM
reficul's Avatar
Help
Make sure all the pins are seated right and not pushed in to far also make sure they are not twisted. Be patient and don't force them. With everything lined up they will push together real easily.
2012 Shark Face
One day he is gonna answer
reficul is offline
post #3 of 9 (permalink) Old 07-03-2013, 09:19 PM
lostboy792's Avatar
I had same problem and it ended up i had all the terminals flipped 180 degrees in the connector. Be patient they will come back out but can be tricky.
2012 Road Glide Ultra, BBP. Jackpot head pipe, V&H Monster ovals, VIED's DIY rear air ride suspension, Progressive Mono Tubes in the front -1.
lostboy792 is offline
post #4 of 9 (permalink) Old 07-03-2013, 09:52 PM
mjsdouble's Avatar
This is where I had trouble too. If you put the pin in correctly you will hear it click into place. It will then be difficult to come out. Once you get the hang of one or two pins its a piece of cake. As has been said ... You might have to rotate the pin 180 degrees.
SWIII, SWIV, SWV, SWVI & SWVII
mjsdouble is offline
post #5 of 9 (permalink) Old 07-03-2013, 10:25 PM
tdkkart's Avatar
I did this too, the pins are likely backwards which prevents the whole connector housing from going back together properly.
tdkkart is offline
post #6 of 9 (permalink) Old 07-04-2013, 01:14 AM
ammojeff's Avatar
I had the same problem. Pins kept twisting. Take it slow partially assemble the lock and red rubber seal and the pins will line up better. At least thats the way I remember it.
AMMO: Giving the enemy the opportunity to die for their country
ammojeff is offline
post #7 of 9 (permalink) Old 07-05-2013, 09:58 PM
Glad I'm not the only one. Just had the same problem this afternoon and had a couple of pins 180* off. Helps to put the white plate in to the first notch to align the pins.
DuraGlide is offline
post #8 of 9 (permalink) Old 07-08-2013, 09:32 PM
Exactly this. Once the plate is in, then put them through the gasket seal in order first. Then plug them into the connector with the white plate seated in loosely. I don't know how folks do it otherwise.
guitarslinger is offline
post #9 of 9 (permalink) Old 07-09-2013, 08:57 AM
Little tab on pins goes towards the center if I remember correctly.
As others have said, put the white plastic piece in only part way. It will click but you can tell it's not completely seated.
Then put your wires in, make sure all are straight and put in as far as possible.
Then push the white piece the rest of the way down until it clicks.
KO
2013 Road Glide Ultra Midnight Pearl
Torqueinc .510 Cam, Fullsac X-Pipe Header, Jackpot Muffs, Fuelmoto A/C, Dynojet P-Vision w Autotune
kiohio is offline
Best way to put Deutsch Connectors back together! 1BadGlide Controls & Handlebars 7 07-10-2013 08:50 PM
Back together after the Paint Job Wooden Nickel Paint & Bodywork Section 38 01-12-2012 11:48 AM
Finally back together! PICS!!!! Sedona Blue *General Road Glide Discussions/Pictures 60 11-11-2011 12:50 PM
Putting the puzzle back together! Sedona Blue *General Road Glide Discussions/Pictures 25 04-02-2011 07:49 AM
HD snap on lowers & HD snap on wind deflector ironmark Aftermarket Accessories 0 12-27-2010 09:46 AM
