brake hand lever question - Road Glide Forums
post #1 of 8 (permalink) Old 07-12-2013, 09:32 AM Thread Starter
Dmize's Avatar
Looks like the front brake lever took the most dmg when my bike fell over this week.
My question is my break level looks different than these ones from the HD parts.
Its hard to explain but the end that butts up to the brake cylnder housing is 'pointed' . these ones... and the ones on the shelf at the dealer are all flat (the pic below)
My controls were already on the bike when I bought it at the dealer... but I have to believe they are HD.
I'll post a pic later, but wonder if anyone knows anything about the different levers.
2010 fltrx
D.Mize
16 CVO RGU
Dmize is offline
post #2 of 8 (permalink) Old 07-12-2013, 10:08 AM
Think it's just design to fit (work), as long as it fits into the housing an the tab hits the plunger (stwich) to activate. Ones my my olKing fit my 03, eeven some metrics might fit
reds4 is offline
post #3 of 8 (permalink) Old 07-12-2013, 12:21 PM
Jetman's Avatar
Metrics will not interact due to how the brake light switch is so different.
I think those pics are generic. As long as you get to fit your year "Touring" it will have that point you describe. I just finished shooting a set of levers this morning & there is a defined difference between the brake and clutch lever by the way they fit into the housing.
Unless you have to have it from HD, I got a nice set of Custom Chrome (black) from Eastern Performance for less than $40.00
2012 - Big Blue Pearl
Heavily Accessorized.....
Jetman is offline
post #4 of 8 (permalink) Old 07-12-2013, 11:20 PM
skratch's Avatar
the ones that you posted will definitely not fit your controls. there is a marked difference between them, other than just the flat vs. 'pointy' part. but i think that hd is just using a generic picture on their website. if you order the correct part, you'll get the correct part.
for example, check out this item, 38843-08 http://www.harley-davidson.com/store...trol-lever-kit
i just put these on the wife's bike, today, and they were correct, but the picture clearly shows them flat (pre 08 style)
skratch is offline
post #5 of 8 (permalink) Old 07-13-2013, 02:28 PM Thread Starter
Dmize's Avatar
so... I'm not the only one with the point? Everyplace I look only has the flat ends listed.
The dealer told me it was a discontinued part, but I'm wondering if they were looking for the "slotted" model that I currently have.
I would preferr aftermarket... HD is nuts 150 a set!
Mine look like this pic below.
These look like they will fit. thoughts?
http://www.easternperformance.com/pr...Touring-Models
D.Mize
16 CVO RGU
Dmize is offline
post #6 of 8 (permalink) Old 07-13-2013, 06:20 PM
faststan's Avatar
That looks like the stock configuration. Mine look the same.....I have the EasternPerformance levers
11 FLTRU 103 Red Hot Sunglow
faststan is offline
post #7 of 8 (permalink) Old 07-13-2013, 07:06 PM
Jetman's Avatar
This is just 1 of many options under $50.00 from Eastern Performance.......
Jetman is offline
post #8 of 8 (permalink) Old 07-13-2013, 07:42 PM Thread Starter
Dmize's Avatar
thanks for the confirmation!
D.
D.Mize
16 CVO RGU
Dmize is offline
Lever Change Kuryakyn Boss Lever 16RGS *General Road Glide Discussions/Pictures 9 03-31-2017 09:45 AM
Extended Brake/Shift Lever Question RoadGlideN8G *General Road Glide Discussions/Pictures 7 04-15-2014 10:06 AM
Billet brake lever installed for rear brake HUTMO Do-IT-Yourself 1 12-27-2012 03:18 PM
Clutch hand lever Mad Hatter Controls & Handlebars 4 03-10-2012 10:56 PM
Hand Lever Instructions PhrogFlyer *General Road Glide Discussions/Pictures 13 03-18-2011 04:25 AM
