Installing New Handlebars - Road Glide Forums
post #1 of 14 (permalink) Old 02-22-2011, 08:36 AM Thread Starter
Just a quick question for those who have changed bars(some several times), is it better to do the exchange on a lift or down on the floor so you can move the front wheel from side to side. I plan on doing the swap out this weekend and your help and or advice would be appreciated....
Thanks
2
twowheel99 is offline
post #2 of 14 (permalink) Old 02-22-2011, 09:02 AM
Roadglide Charley's Avatar
Did mine from the floor, nothing down low that you need to have the bike lifted for
Roadglide Charley is offline
post #3 of 14 (permalink) Old 02-22-2011, 10:53 AM
staush's Avatar
Depends on the bars. If they are higher or pulled back a couple of inches then a lift would be helpful because you'll be changing the brake lines and the clutch cable and the hand grips etc: etc:. Have fun , and make sure you have all the misc. parts on hand before you start or you'll be making a half dozen trips back and forth to the dealer.Sounds worse than it is and it's one of the best things to do for riding comfort.
staush is offline
post #4 of 14 (permalink) Old 02-22-2011, 11:01 AM
Thanks
2
I used the lift some of the time and other times the bike was on the floor. Ya see, why bend over when you can bring the bike up to you . LOL. You don't really need a lift though.
Also make sure you look at the post with step by step and pictures. I wist I would have seen the post before I did my job. Would have gone much faster.
post #5 of 14 (permalink) Old 02-22-2011, 12:32 PM Thread Starter
I guess I wasn't to clear, I don't want to tie it down on the lift have the front wheel in the chock and then need to turn it to access something (does this make sense)? Plus someone mentioned additional parts? I plan on re-using everything from the original bars, or am I missing something there also. I read everyones post and look at the one Donk submitted, I'm not afraid to tackle the job but I want to be prepared for everything I might encounter......
Thanks for all the help & advice.....
post #6 of 14 (permalink) Old 02-22-2011, 07:16 PM
You want to be able to turn the wheel/ Handle bars to access the inner torx screws that secures the Speedo/Tach. cover, and turn signals.also move wires around.
I replaced original bars with Heritage bars and no extra parts needed.
post #7 of 14 (permalink) Old 02-22-2011, 07:28 PM
i like having the bike level but on the floor. I use my floor jack to keep the bike level but it allows me to turn the bars side to side.
jeff is offline
post #8 of 14 (permalink) Old 02-22-2011, 07:28 PM Thread Starter
Thank You Sir
post #9 of 14 (permalink) Old 02-23-2011, 04:56 AM
Donk's Avatar
I did not use a jack or lift, and simply because I had to turn the front wheel several times to loosen the bolts on the forks that hold on the plastic trim pieces, and the inner turn signal bolts to remove the fairing.
As long as you have bars that are no bigger than 12- 14 inch apes there is plenty of extra wire under the fairing, plenty of clutch cable and plenty of brake line. No extra parts needed. Good luck to you.
Donk is offline
post #10 of 14 (permalink) Old 02-23-2011, 06:38 AM
aclass's Avatar
Twowheel99, I thought you got all of your advice from the guy on the orange/black screamin eagle RG???
What bars you going with? My monkey bars came yesterday but havent got the lines yet so I'll be a week or two behind. Good luck and keep us posted.
aclass is offline
Installing new exhaust AlMohr Intake and Exhaust 8 06-04-2012 02:02 PM
throttle cable handlebars and tbw handlebars Swagzilla Controls & Handlebars 2 01-30-2012 07:30 PM
Installing new handlebars today Kevian Controls & Handlebars 19 08-31-2011 10:52 AM
Installing New Handlebars twowheel99 Controls & Handlebars 3 02-28-2011 05:14 PM
installing new yaffe bars rite now quato102 Controls & Handlebars 12 09-28-2010 09:39 PM
