What size clutch cable with 12" monkey bars - Road Glide Forums
post #1 of 6 (permalink) Old 02-22-2011, 04:03 PM Thread Starter
pennstater's Avatar
I installed the 12" monkey bars and rerouted the clutch cable, but it hits a bolt head on the side of the fork. Does anyone know what size of cable I should get? Everything else came out great.
pennstater is offline
post #2 of 6 (permalink) Old 02-22-2011, 04:17 PM
RedDogNC's Avatar
I would like to hear this answer as well. And while we are on the subject of 12" OEM Monkey Bars are there any cheaper sources than going directly though PY? I have found the 10" in different places the best being $325 shipped, but what about the 12"? Thanks
RedDogNC is offline
post #3 of 6 (permalink) Old 02-22-2011, 04:31 PM
Check the past post
YOU can keep the stock, Did mine and still have the cables sitting in the box.
Cut the zip ties and run the whole thing between forks. Take the stock brake and twist it to the right, this will cause it to stay close to the handle bars and there will be no need for ties on bars. ENJOY
Frodoe is offline
post #4 of 6 (permalink) Old 02-22-2011, 04:49 PM Thread Starter
pennstater's Avatar
Between the front forks????
post #5 of 6 (permalink) Old 02-22-2011, 04:58 PM Thread Starter
pennstater's Avatar
I think you mean the down tubes on the frame. Mine runs in front of the cross brace and is zip tied. Did you cut the zip tie and run it behind the brace and if so don't you have to worry about it being to close to the exhaust?
Thank You
post #6 of 6 (permalink) Old 02-22-2011, 05:33 PM
CHAINSAW's Avatar
Thank You
I've had mine ziptied to my frame on the engine side for 8,000 miles... no problems with the heat on the clutch cable at all.
Frodoe is right,.. cut the zip ties, reroute it behind the frame and behind the triple trees and you will have enough slack.
Such is the rule of honor.
CHAINSAW is offline
Changed clutch cable to +6 cable...clutch does not appear to engage backwaterdogs Troubleshooting for Road Glides 4 05-20-2017 08:09 PM
12" Monkey Bars Clutch Cable issue??? DOCSGT Controls & Handlebars 2 02-22-2014 06:04 PM
How did you run your hydraulic clutch cable on Monkey Bars??? 1BadGlide Controls & Handlebars 1 05-20-2013 07:59 AM
12" Monkey Bars with 12" WindVest Shield? Tek74 Controls & Handlebars 3 02-13-2012 07:50 PM
Cable size for 12" oem monkey bars pennstater Controls & Handlebars 11 02-20-2011 08:21 PM
