when is shimming brake needed? - Road Glide Forums
post #1 of 12 (permalink) Old 07-25-2013, 05:12 PM Thread Starter
installing 10" monkey bars using stock cables. I think im ready to tackle this but still a little confused on the shimming of the brake lever? Can someone clarify? Thanks
Luke Duke is offline
post #2 of 12 (permalink) Old 07-25-2013, 05:34 PM
Deadstroke's Avatar
U dont have to do anything you will be good, I would recommend that you either change the TBW to the screaming eagle or extend the wires a little. You can do it with out it but it is a pain
Deadstroke is offline
post #3 of 12 (permalink) Old 07-25-2013, 05:43 PM
ftb2ss's Avatar
If you remove your brake controls off the handlebar you have to shim your brake lever. Just put a small piece of cardboard on the left side where the handle comes out of the housing. Jam it between the end of the lever and the housing. You can search these forums to find out what happens if you don't. The manual actually warns you to do this for proper break actions after your done.
2011 Vivid Black RGU "Buta Same"
ftb2ss is offline
post #4 of 12 (permalink) Old 07-25-2013, 05:43 PM
If you are taking the switch housings off stick a piece of cardboard in between the lever and the housing or the switch will break when you take off the housing. Pull on the brake lever and stick the cardboard in the space it creates.
HogPro is offline
post #5 of 12 (permalink) Old 07-25-2013, 06:09 PM
Deadstroke's Avatar
huh i never did that, didnt have a issue guess i got lucky
post #6 of 12 (permalink) Old 07-25-2013, 06:14 PM
tdkkart's Avatar
Ive never done it either, never had a problem. Gotta remember, their manuals are written for mallet-fisted dealer techs.
tdkkart is offline
post #7 of 12 (permalink) Old 07-25-2013, 06:38 PM
Shark of the Month August 13
SIC_26's Avatar
I've done 20+ set of bar swaps and never done it either.......as long as your careful with the R&R your fine :thumbup:
But people to break them regularly
SIC_26 is offline
post #8 of 12 (permalink) Old 07-25-2013, 06:42 PM
for myself to be on the safe side any time I am messing with the front brake side I shim the lever , cheap and easy insurance against an unneeded expense and repair.
Eagle
Eagle is offline
post #9 of 12 (permalink) Old 07-25-2013, 06:52 PM
Shimming just helps from breaking the brake switch nub off when re installing. Its not necessary if you know what your doing and are careful when putting it back together.
Just squeeze your brake lever in and shove a piece of cardboard in the gap to hold the handle in before removing any screws. Remove cardboard when its all back together.
post #10 of 12 (permalink) Old 07-25-2013, 08:25 PM Thread Starter
Thanks for the tips.
You say extend the tbw is that to get the green connector out of the bars? what is the screaming eagle?
Brake hoses needed Big_gary General Off-Topic Discussions 1 04-18-2016 07:56 PM
Brake Line Needed - Single Side 13" Rotor PM Caliper OpenRoadRG Wheels and Tires 0 08-31-2015 01:47 PM
Advice needed for Tour Pack w/ running and brake lights to RGC McGruder Aftermarket Accessories 7 06-07-2015 06:35 PM
Has anyone tried shimming the fairing bracket to reduce vibrations? Driftah Do-IT-Yourself 5 05-12-2014 09:49 PM
Front brake lines needed caboverbob Equipment-RG 15 01-22-2013 01:54 AM
