Anyone add the hydraulic clutch??? - Road Glide Forums
post #1 of 9 (permalink) Old 07-26-2013, 02:24 PM Thread Starter
RoadGlideRider's Avatar
I have an '09. I have thought about adding the hydraulic clutch to previous models I have owned.
I was wondering if anyone here has done this and if so how hard was it to install?
Also I was wondering about what did the entire installation cost?
Any information will help.
RoadGlideRider is offline
post #2 of 9 (permalink) Old 09-22-2013, 10:50 PM
Thumbs up Hydraulic Clutch
I added the hydraulic clutch setup to my 2011 Road Glide Ultra. It cost around $1000.00 and caused a few issues that I had to over come due to the dealer not knowing what they were doing. Once I fixed the issues I would not go back to the cable setup. I love the new feel and action.
TallRider is offline
post #3 of 9 (permalink) Old 09-22-2013, 10:54 PM Thread Starter
Thanks for the response.
And it took two months to get one.
post #4 of 9 (permalink) Old 09-23-2013, 07:53 PM
Can I do a hydraulic on my 08?
I never saw a wild thing feel sorry for itself.--DH Lawerence
Tackdriver is offline
post #5 of 9 (permalink) Old 09-23-2013, 08:50 PM
$1000...... did that include a new clutch? I was thinking about doing a hydraulic set up because I have the SE race clutch, and it's rather stiff, but for that kind of $$$$$ I think I'll just deal with it.
Sent from my SPH-L710
post #6 of 9 (permalink) Old 09-24-2013, 02:44 PM
93-331-29psi's Avatar
You should be able to do hydraulic on any of the 6 speed bikes.
93-331-29psi is offline
post #7 of 9 (permalink) Old 09-24-2013, 09:24 PM
I want to see a parts needed list. talked it through with local HD parts mgr.
hyd hose
trans cover for hyd set up
clutch actuator for inside trans
rod from actuator to clutch
hyd reservoir on handlebar
clutch lever
zip ties
Any thing else?
jethro_3 is offline
post #8 of 9 (permalink) Old 09-24-2013, 10:00 PM
oofly's Avatar
The stock clutch is really easy to pull in. No need to spend $1000. I put the screaming eagle spring plate in and it isn't that bad. I have a 77 400 Maico you can pull that thing in say 40 times and you are done
Sent from Motorcycle.com App
2011 RGU Vivid Black
Death Valley on the way to SWIII
oofly is offline
post #9 of 9 (permalink) Old 09-25-2013, 10:25 AM
hyd hose
clutch lever
zip ties
Any thing else?
I put this list together a couple years ago when I contemplated the same thing on my '09
Hand Control PArts
42101-09 MASTER CYLINDER ASSEMBLY, CLUTCH (CHROME) 294.00
42119-08 CLAMP, MASTER CYLINDER (CHROME) 59.99
4293 Clamp SCREW (x2) 1.00
6099 Clamp WASHER (x2) 1.49
38774-08 LEVER ASSEMBLY, HAND, 79.99
41751-06A GASKET, BANJO-BOLT (x2) 1.49
42010-06A BOLT, BANJO 12.49
38898-08A LINE ASSEMBLY, HYDRAULIC-CLUTCH 109.99
Line clamp parts
1001 SCREW 1.49
6703 WASHER 0.99
7688 NUT 1.49
38938-09 RETAINER, CABLE 18.49
Transmission Parts
37137-07 SIDE COVER, TRANSMISSION (CHROME) 299.49
4718A Side Cover SCREW (x4) 1.49
4741A Side Cover SCREW (x2) 0.99
36805-06 GASKET, COVER 5.49
6822-04 SLAVE CYLINDER KIT 39.99
The prices were all retail with no discounts.
Anyone convert clutch from hydraulic to cable on a '15 or newer? VDeuce *General Road Glide Discussions/Pictures 4 03-14-2018 06:17 PM
Has anyone installed a hydraulic clutch on RG or RGU (non-CVO)? 2012FLTRU_BigBlue Controls & Handlebars 1 06-19-2013 06:36 PM
Hydraulic Clutch throwing trouble code 69 A-body Controls & Handlebars 3 08-29-2011 08:10 PM
Hydraulic Clutch DonL Controls & Handlebars 6 01-24-2011 08:24 PM
New pipes w/ hydraulic clutch? Pokerstar Intake and Exhaust 0 12-25-2010 10:25 PM
