Wiring Issues - Road Glide Forums
post #1 of 3 (permalink) Old 07-30-2013, 11:29 AM Thread Starter
Wiring Issues
I have attempted to install new bars and yes I tried to do it with the green TBW connector still attached. Which from my reading here is 95% of the time going to cause me problems. Of course with my luck I believe it has. I am getting 2 ECM error codes, P1510-Throttle actuator control limited performance and (one other code for TBW didn't bring it to work with me) and also U1040-Loss of ABS serial data. I also have the cruise control light alternating flashing red and green. I am going to try and pull the green connector back enough to cut green piece out and solder the connection without having to pull it all back through again. So my question is will removing that connector eliminate all the error codes? What does the flashing cruise light mean? Thanks for any input, I am really under the gun to get this complete.
infernomd is offline
post #2 of 3 (permalink) Old 07-30-2013, 11:37 AM
OKBigD's Avatar
Either cut and splice to remove the green connector and ensure that the wires are all in their correct position, or replace the entire TBW with the screaming eagle 32310-08 twist grip sensor. Also did you cut or dis-assemble the hand controls. If so make sure they are all pinned out properly....
OKBigD is offline
post #3 of 3 (permalink) Old 07-30-2013, 01:01 PM Thread Starter
I cut the hand controls and reverified that the colors matched. I will check the service manual to see what the cruise wires and verify that the soldered connection is ok.
How hard is it to run the CVO extended TBW line while the control wiring is already in place? Or do I need ot pull both and run them again?
How To Fix TBW Issues After Internal Wiring Donk Controls & Handlebars 164 07-12-2018 01:11 PM
Issues after wiring internal SnowBandit Controls & Handlebars 16 06-15-2013 12:25 AM
07-08-09 Problem Issues joke *General Road Glide Discussions/Pictures 13 01-17-2011 02:19 PM
Rinehart fitment issues CustomGlide Intake and Exhaust 0 04-23-2010 10:59 PM
rear lighting issues ofscout Lighting 3 02-26-2010 07:57 AM
