ok changed bars, zero power - Road Glide Forums
post #1 of 11 (permalink) Old 07-30-2013, 08:45 PM Thread Starter
just like it says all connections made, everything looks to be correct, turn switch on and get nothing, no power period, any suggestions
Rcrook is offline
post #2 of 11 (permalink) Old 07-30-2013, 09:38 PM Thread Starter
ok got power but still no start,, sounds like can here the fuel pump, noticed the yellow light does not come on in the speedo when switch is 1st put to run, bike turns over just dont start
Rcrook is offline
post #3 of 11 (permalink) Old 07-30-2013, 09:53 PM
fltreagle's Avatar
When I changed my bars, I broke a wire on the throttle by wire setup, it would start up but onlu idle! So it may be that set of wires from the TBW. I was told you can't cut and either extend or shorten the wires, somehow they are set for the resistence, any change and it doesn't work.
fltreagle is offline
post #4 of 11 (permalink) Old 07-30-2013, 10:42 PM
faststan's Avatar
You need to go back and check each wire on both sides. One or more wires are not plugged in correctly or or broken. I have changed several bars and had to reverse my steps to find the problem. Could be neutral switch on clutch side. Could be TBW wires. The main problem people have is with the green connector in the TBW bundle. Wires can be cut and spliced without worrying about resistance.
11 FLTRU 103 Red Hot Sunglow
faststan is offline
post #5 of 11 (permalink) Old 07-30-2013, 10:52 PM Thread Starter
what a pain in the ass, no wonder Harley charges what they do, wonder if they even charge enough, anyway found what it was 3 beers later, when I draw my picture of the connector with wire colors I put w/b down twice, white/black and looking at the wires there was another w/b white/blue, they where reversed,
glad I took some pictures of they throttle side, that's how I found it, so all is good in the world tonight, but tomorrow brings another day
Rcrook is offline
post #6 of 11 (permalink) Old 07-30-2013, 11:30 PM
Trip20's Avatar
Me and a buddy were double checking each other as we called out the colors for our diagram we drew to document the connectors. It is too easy to mix it up like this. Glad you figured it out!
2013 FLTRX
Trip20 is offline
post #7 of 11 (permalink) Old 07-31-2013, 03:13 AM
Besides the wire mix up. How was the install over all. Also, what bars did you use. Thanks, I am in the process of learning everything I can before I do it myself. Right now I am between the wild outlawz, LA chopper13" apes, or the buky males. In 14".
2012 Black Denim RG Custom / 14" Bad Seed Bars / Rush Slip-ons / Harley Boom Speakers / Kuryakyn Grips / Extended Toe and Brake levers / Hidden Fairing Antenna / 14" Light Smoke Windvest / C&C Seat / Stage 1 & SERT / Mean Mug
Mason417 is offline
post #8 of 11 (permalink) Old 07-31-2013, 06:34 AM Thread Starter
12 mad doggers, , if it wasn't for fly by wire it wouldn't be that bad of a job, just too much wire going in the bars on throttle side, anyway just need to zip tie some wires, rewrap one connector, adjust my switches, and put fairing on and that should be that
Rcrook is offline
post #9 of 11 (permalink) Old 07-31-2013, 07:07 AM
Did outlawz on my RGU. Bars feel great but it was a pain getting the wires to make the 90 deg angle at the bottom of the bars. Bars with a curve at the bottom are easier to wire.
DuraGlide is offline
post #10 of 11 (permalink) Old 07-31-2013, 09:42 AM
faststan's Avatar
I recently put 14" Outlawz on my bike. I used a string with a nut on the end to get string thru bars. Then, tied a knot in string at bar end, taped a couple of wires to the knot and pulled. Took about 10 minutes start to finish. The large bundle is a pia. Doing several wires at a time makes the 90 degree turn much easier. I always tape the wire ends to keep them from interfering with the turn. This is the 4th set of bars I have put on and gets easier all the time. For the bars with the curves I use a 4 ft zip tie and tape all wires to the end of the zip tie and pull/push slowly.
faststan is offline
Zero sound - Radio lights on jtfoto Audio 9 04-05-2013 01:06 PM
Oil Temp gauge won't come off zero peg SickRick Troubleshooting for Road Glides 8 10-08-2012 07:11 PM
Ground zero? crazyredneck Road Trip Discussions/Stories/Pictures 4 09-12-2012 07:09 AM
Voltage meter reads zero and red light RoadGlide0611 Troubleshooting for Road Glides 3 05-17-2012 05:32 PM
