Removing pins from connectors - Road Glide Forums
post #1 of 13 (permalink) Old 08-10-2013, 02:50 PM Thread Starter
I am going to be replacing my OEM handlebars with 12" Chubby's Wild 1 Outlaws and am wondering if there is a special tool required to remove the pins at the end of the controls where they go into the connectors. I have some small screwdrivers along with hook and O ring removal tools, will I need another tool?:
Your word is your bond.
bullet is offline
post #2 of 13 (permalink) Old 08-10-2013, 03:20 PM
Needle nose pliers to pull the inside of the plug open and a paper clip to release wire. That's all I use. You can buy a tool for molex plugs but its not necessary.
pittz5 is offline
post #3 of 13 (permalink) Old 08-10-2013, 03:31 PM
Memphisglide's Avatar
Get the manual or a copy as it shows how they all come apart! Invaluable
2016 Road Glide Special - Black Quartz
Memphisglide is offline
post #4 of 13 (permalink) Old 08-10-2013, 06:25 PM
Here's the molex tool from the Custom Chrome catalog. Paper clip is a lil cheaper!!! Good luck!
http://customchromecatalog.com/2013/full.asp?page=1009
"GRIP IT AND RIP IT!!!
HOGPRO SUCKS!
DON'T BUY FROM THEM
JaySlo is offline
post #5 of 13 (permalink) Old 08-10-2013, 07:16 PM
zemo1017's Avatar
Seen several on Fleabay anywhere from $11 to $30.
zemo1017 is offline
post #6 of 13 (permalink) Old 08-10-2013, 08:30 PM
SBR_GUY's Avatar
Post #5 & #6 shows you how to take the plug apart.
https://www.roadglide.org/showthread.php?t=5694
The difference between you and me, is I run towards gunfire.
SBR_GUY is offline
post #7 of 13 (permalink) Old 08-10-2013, 09:17 PM
Hullhorr's Avatar
A paperclip does work, but an actual tool is a little easier. The hardened metal of the tool will not bend like a paperclip will. They can be had on eBay pretty cheap.
2009 FLTR MOP
Hullhorr is offline
post #8 of 13 (permalink) Old 08-10-2013, 09:40 PM
shermanator's Avatar
Use the paperclip from the backside of the connector. Maybe it was just me but I fiddled with that connector for the longest time try to release pin from the wrong side even with the instructions in front of me. After I figured it out it was a breeze.
shermanator is offline
post #9 of 13 (permalink) Old 08-10-2013, 10:44 PM
mjsdouble's Avatar
A paper clip and needle nose pliers is all you need. There's a lot of info in the handle bar threads.
List of tools needed and institutions
https://www.roadglide.org/showthread.php?t=4745
Helpful thread on the wiring
https://www.roadglide.org/showthread.php?t=17569
Good luck with the bars.
SWIII, SWIV, SWV, SWVI & SWVII
mjsdouble is offline
post #10 of 13 (permalink) Old 08-11-2013, 05:45 AM Thread Starter
Thanks for all of the posts guys, very helpful. Here goes nothin.
bullet is offline
Harmon Kardon Socket Connectors, Pins - BUY HERE 2012FLTRU_BigBlue Miscellaneous for Sale 10 04-16-2015 09:04 AM
Removing Trap Door without removing Exhaust kevanbo Do-IT-Yourself 7 04-03-2014 06:01 PM
pins inside the weather pack connectors Bubba Controls & Handlebars 8 02-16-2012 08:30 PM
Corbin Heated Seat Connectors 2011redrider Seating: seats, backrests 0 11-20-2011 06:43 PM
Posi-Lock Connectors DreamRider Videos 6 10-16-2011 08:09 PM
