Accessory Switch (on Instrument Nacelle) - Road Glide Forums
post #1 of 7 (permalink) Old 08-12-2013, 07:13 PM Thread Starter
Help - can someone point me to the 'affected' plug relative to the 'Fork / Instrument Accessory Switch' on my 11 Road Glide ??
car t shark is offline
post #2 of 7 (permalink) Old 08-12-2013, 07:41 PM
throttles&triggers's Avatar
Check the info on this related thread.
https://www.roadglide.org/showthread.php?t=16554
Scroll to pages 10-12 below.
http://www.epiphanybullterriers.com/...ewsLetter2.pdf
Here is the HD switched harness:
http://www.harley-davidson.com/store...dapter-harness
Here is some other information that may be helpful:
The receptacle is located under the seat and is a plastic dark colored rectangular box with a sealing plug in one end and 4 wires coming out the other end. This connector is a 4 pin Deutsch DT series. It has nothing to do with your Aux lights or the switch that controls them.
These are the circuits that the Acc switch controls.
Circuits For Touring Models:
Pin 1 Orange/Red - Circuit powered when Ignition ON or ACC position
Pin 2 Red/Yellow - Circuit powered when Brake Light Circuit (on when brakes are applied)
Pin 3 Orange - Circuit powered when Ignition ON or ACC position and nacelle switch ON
Pin 4 Black - Battery Ground
throttles&triggers is offline
post #3 of 7 (permalink) Old 08-12-2013, 08:39 PM
Damn I was just going say that lil box plug under the seat in front of the battery, the one i spliced into
reds4 is offline
post #4 of 7 (permalink) Old 08-12-2013, 08:50 PM
I find that the more complicated you make it sound, the easier it turns out to be!
post #5 of 7 (permalink) Old 08-12-2013, 09:16 PM Thread Starter
Well Throttles - I 'think' I may have found it ??? In an '11, is it here at the fuse box Sir ?? Or should I pull the battery to find it ??ImageUploadedByMO Free1376360152.357676.jpg
I couldn't detect power w' my meter the other day when I tried this plug
Thanks Everyone for your input
File Type: jpg ImageUploadedByMO Free1376360112.017096.jpg (15.9 KB, 18 views)
post #6 of 7 (permalink) Old 08-12-2013, 10:15 PM
Triplej's Avatar
Originally Posted by car t shark View Post
Well Throttles - I 'think' I may have found it ??? In an '11, is it here at the fuse box Sir ?? Or should I pull the battery to find it ??Attachment 46137
That is not the plug you are looking for. Its the one located under the seat you will need to plug into for accessory power. Sorry the pic is kind of fuzzy but you should get the idea.
Triplej is offline
post #7 of 7 (permalink) Old 08-12-2013, 10:23 PM Thread Starter
Awesome - ill try to find it tomorrow after work ?? Thanks Again for everyone's Help !!! Means the World to Me !!
Accessory Switch? Ezgoin721 *General Road Glide Discussions/Pictures 66 07-29-2016 11:40 PM
??? Accessory Switch BLACKHAWK Aftermarket Accessories 2 11-27-2011 04:12 PM
Accessory Switch Wire 1st Sgt Aftermarket Accessories 11 06-04-2011 08:19 AM
Accessory switch question Rsmith Road Glide Specific Discussions 16 03-20-2011 09:31 PM
Accessory switch termination? longrides *General Road Glide Discussions/Pictures 1 09-29-2010 04:32 PM
