Extending your brake line? This could save you money - Road Glide Forums
  • 1 Post By Sincecrazy
post #1 of 2 (permalink) Old 03-05-2010, 01:48 PM Thread Starter
Sincecrazy's Avatar
How to save money when extending your brake lines. If you buy the traditional replacement parts to extend your lines it will run a Ben Franklin+. This is normally three brake lines, a threaded junction block and fittings. After looking at the stock setup on my 08 RG, I thought I could cut out two of the brake lines and threaded junction block being replaced.
The first step was to buy a double flairing tool. These can be had for around $20. You will also need a 3/16 brake line fitting. Cut off the upper brake line from the junction block just behind the hose crimp. You need the line to be as long as possible for the flair tool to have enough to work with after the fitting is put on. Debur the inside of the brake line, and bevel the outside of the line where is has been cut. Follow the directions to flare the line as included with the flairing tool. I had to straighten the line just a bit so the fitting would slide down further on the line to allow enough room for the flairing tool to work. After I flaired the line I pressure tested it and checked for leaks. Now all I have to do is measure the one line from the junction block to the master cylinder and order a hose. Aftermarket distributors like J&P Cycles can sell you an individual line and banjo fitting to connect to your master cylinder for around $50.
mzierk likes this.
Sincecrazy is offline
post #2 of 2 (permalink) Old 07-16-2018, 03:58 AM
mzierk's Avatar
old post but got a old bike, just the info i was looking for, thank you Sincecrazy!
mzierk is offline
Paddle deflectors on a 2015 - Save your money Garemlin *General Road Glide Discussions/Pictures 4 10-03-2014 03:20 AM
Best Tire deal Online!!!! Save your money! Scootin Wheels and Tires 6 07-24-2014 10:49 AM
Save your money on "plug and play" 13candyorange Lighting 10 12-23-2013 09:33 PM
How do you save money for your mods? Q-Hog *General Road Glide Discussions/Pictures 58 12-31-2012 03:00 PM
