using 2010 controls on a 2007 RG - Road Glide Forums
post #1 of 3 (permalink) Old 08-18-2013, 09:34 PM Thread Starter
My buddy is getting a new set of handlebars for his 2010 RG, He is getting rid of a nice set of 12" yaffee apes with nice grips and mirrors. He said I can have his old stuff because he is replacing everything. I know my 2007 RG has a throttle cable and his does not. I would really like to be able to use as much of his stuff as possible to avoid having to spend more money. Will his clutch and brakes lines from a 2010 work on my 2007? and does anyone know if his wire connectors will plug up to mine?
Any advice is much appreciated.
Thanks,
raisincain is offline
post #2 of 3 (permalink) Old 08-18-2013, 10:18 PM
93-331-29psi's Avatar
I do believe that the wiring connectors changed from '07 and again but maybe it was '06. Also note that your left side controls have the PTT and his '10 does not. Check with Ronnie's HD site and check part numbers to be certain.
I can't say for certain on the clutch line and brake hose (I know the newer calipers have metric banjo bolts though)
Sent from Motorcycle.com App
93-331-29psi is offline
post #3 of 3 (permalink) Old 08-19-2013, 03:22 PM
I installed a set of 2010 controls on my '07 last winter, when I converted my Road King. I needed to change the lower right hand switch housing to accomodate the cable throttle. I had previously swapped the master cylinder and clutch perch out for the 08 and newer style. Are you also getting the clutch perch and master cylinder in the package? With the 12" apes, you'll probably need to change to a longer clutch cable and brake lines anyway, at least I did when I changed from heritage bars to 12" Monkey Bars.
Built, not bought. 2007 FLHP. Raked, stretched, 107 motor, Road Glide conversion. Garage built bike
jetlag is offline
Using hand controls emptyking Audio 22 10-01-2014 04:34 PM
WTB 2007 FL touring swingarm setup and 2007 streetglide wheel my98glide Wanted! (Buy or Trade) 0 04-03-2013 08:08 PM
Question about Left Hand controls on 2007 FLTR WhiskeyB Controls & Handlebars 1 07-09-2012 08:46 PM
iPod control using handlebar controls Joel Daniels Audio 0 05-17-2012 10:27 AM
2009-2010 vs. 2007-2008 JuicedHD *General Road Glide Discussions/Pictures 16 02-25-2010 04:51 PM
