handlebar suggestions? - Road Glide Forums
post #1 of 29 (permalink) Old 08-20-2013, 11:35 AM Thread Starter
Rgc13owner's Avatar
Any suggestions on bars with some added height and pullback that don't require extra wiring? I'm looking for something that I don't have to reach for as much and that won't cost me arm and leg to install. Thanks in advance for any input
Rgc13owner is offline
post #2 of 29 (permalink) Old 08-20-2013, 11:59 AM
perrykw's Avatar
I recently installed the Heritage Style bars on my ultra. They cost under 80 bucks. If you're careful, you don't have to replace te TBW sensor. They're a pain to install, but it's a DIY project if you follow the threads on here.
perrykw is offline
post #3 of 29 (permalink) Old 08-20-2013, 12:02 PM
mmfinn's Avatar
+1 on the Heritage bars. Installed on my RGC with no cable issues.
mmfinn is offline
post #4 of 29 (permalink) Old 08-20-2013, 01:02 PM
Effenglide's Avatar
I was on the fence with this too. Sorry I waited so long to do it. It's worth it!
Sent from Motorcycle.com App
2005 FLTRI Pearl Yellow
2011 FLTRX Sedona Orange
2015 FLTRS Superior Blue
Effenglide is offline
post #5 of 29 (permalink) Old 08-20-2013, 02:41 PM
Xaran's Avatar
I went with Heritage Style bars from HD they are less than 80.00 and no cable or wiring to change. They will give you almost 2" or Cycle Visions +2 they are the same as stock RGC bars but 2" taller cost more at about 150.00
If you get into any of the other aftermarket bars you will be looking a 100-300 for the bars and any extra cables or wiring.
Xaran
Previous HDs
2004 Road King Custom - SOLD
Xaran is offline
post #6 of 29 (permalink) Old 08-20-2013, 02:46 PM
PGR
PGR's Avatar
Another vote for the Heritage bars.
Ron..........................
PGR is offline
post #7 of 29 (permalink) Old 08-20-2013, 02:51 PM Thread Starter
Rgc13owner's Avatar
Are the heritage bars about the same height position as the stock ones just 2" closer to the rider? I'm not worried about spending some money, but I'm not willing to spend the 1k I was quoted by a dealer.
post #8 of 29 (permalink) Old 08-20-2013, 03:05 PM
r0de_runr's Avatar
I need to answer this same question. I'd like to have bars just a inch or two closer, but more importantly I need to rotate my wrists a few degrees towards the outside. Pinkies a bit lower, thumbs a bit higher.
Right now my hands are too flat in relation to what ergonomics I prefer.
r0de_runr is offline
post #9 of 29 (permalink) Old 08-20-2013, 03:20 PM
perrykw's Avatar
according to the harley parts catalog, the heritage bars have 3 inches more pullback than the stock bars. mine don't feel any higher, and honestly don't look like they have any more pullback. I can't "see" a difference, but I can definitely feel it.
As far as 1,000 bucks to install, they must be on crack. It did take me a half a day to install them, but mainly because I had NO CLUE what I was doing. I have ridden metrics for the last 4 years, so I am new to the Harley world. Not to mention that my bike is only a couple weeks old so I was extremely scared I would mess something up. To me, it was a very straightforward install using the step by step on the forum.
Like the others have said, no cable or hose rerouting. I didn't even disconnect my brake line. Just took the clamps off and layed everything across my towel-covered tank
perrykw is offline
post #10 of 29 (permalink) Old 08-20-2013, 03:25 PM
OKBigD's Avatar
If you're comfortable with moderate wrenching, than buy what you like and do it yourself.........
I went with the 12" Buky Bars Maddoggers.. Just cut and solder the green connector on your throttle sensor, or buy a new CVO throttle sensor for 85$. No cable extensions needed for hand controls, brake line was more than long enough, just easily re-routed the clutch cable.... I got 1.5" bars so internal wiring was extremely easy... I attached a pic after install....
OKBigD is offline
Wiring Suggestions for Handlebar Change mrauenzahn Controls & Handlebars 1 01-21-2015 06:47 PM
Handlebar height suggestions TLKurtz Controls & Handlebars 16 05-04-2012 10:31 PM
Radio suggestions to replace HK? Sincecrazy Audio 34 01-27-2012 06:14 PM
Seat suggestions silverglider Seating: seats, backrests 9 05-30-2010 05:11 PM
Suggestions about Handlebars & Mirrors twowheel99 Controls & Handlebars 23 05-21-2010 07:30 AM
