Blinkers not working?? - Road Glide Forums
post #1 of 7 (permalink) Old 08-27-2013, 07:31 PM Thread Starter
I installed new bars and had the front & rear light bezels powder coated and now the blinkers don't work. The rear stays bright constantly (and won't blink) and the front wont blink either (one won't light up at all). The indicators work on the dash and all other handlebar controls work fine. Need help please!!!
Bodawg1 is offline
post #2 of 7 (permalink) Old 09-03-2013, 02:59 AM
SBR_GUY's Avatar
Did you run the wires internal? If so I would start there. Also Did you do the powder coat and the bars at the same time? If not did the lights work before the powder coat? If they did it maybe a ground issue. If not then check your wire splices for the bar install.
The difference between you and me, is I run towards gunfire.
SBR_GUY is offline
post #3 of 7 (permalink) Old 09-03-2013, 09:16 AM
laxinharley's Avatar
Are the rears bright because the brake lights our on constantly. If so you may have broke the brake switch. Just a thought.
laxinharley is offline
post #4 of 7 (permalink) Old 09-04-2013, 09:06 PM
garbage cannon's Avatar
Location: On the southern shore of Lake Arthur of Moraine State Park. About 40 miles north of Pittsburgh
I just changed the bars yesterday and then my brake light is stuck on. I disassembled the controls on that side and the switch wasn't being engaged correctly. I put it back together now it's intermittent. Maybe your switch is stuck out too.
It's funny how we keep expecting leaders from a system that rewards weasels.
garbage cannon is offline
post #5 of 7 (permalink) Old 09-04-2013, 09:10 PM
Mike U's Avatar
If you ran your wires through the handlebars check to make sure that you replaced the wiring in the harness properly.
Best of Luck!
Mike U.
USMC 1975-1977
Semper Fi!
Nothing else matters!
Mike U is offline
post #6 of 7 (permalink) Old 09-05-2013, 08:01 AM
Phantom6722's Avatar
Blinkers constantly on usually means a bad or open earth connection. I would undo all your connections again check for correct wiring and make sure all earth connections are tight.
Cheers Skip
Phantom6722 is offline
post #7 of 7 (permalink) Old 09-05-2013, 09:34 AM
What ever you do- don't get water in them
reds4 is offline
Neutral light on cruise not working and gear indicator not showing Xman247 Tools and Garages 7 08-11-2018 11:09 AM
Blinkers not working?? Bodawg1 Troubleshooting for Road Glides 0 08-28-2013 07:56 AM
Blinkers Stopped Flashing Double0 Troubleshooting for Road Glides 2 09-25-2012 06:08 AM
arlen ness blinkers drmudd Lighting 15 02-14-2012 03:25 PM
blinkers Graybone32 General Off-Topic Discussions 2 01-16-2012 09:42 AM
