How tall without extending wires - Road Glide Forums
post #1 of 14 (permalink) Old 09-02-2013, 10:53 AM Thread Starter
glidin13's Avatar
anyone recommend bars for a taller guy that doesn't require extending the wires ? "I'm 6'3.
glidin13 is offline
post #2 of 14 (permalink) Old 09-02-2013, 11:05 AM
ichiban's Avatar
I must have read every bar posting for the past two years. You can only go 12" using stock harness.
ichiban is offline
post #3 of 14 (permalink) Old 09-02-2013, 11:07 AM
pat123's Avatar
I think you can go 12 inch without extending the wires. The wiring isn't hard, just take your time. Being over 6ft your going to want higher than 12's
pat123 is offline
post #4 of 14 (permalink) Old 09-03-2013, 03:07 AM
SBR_GUY's Avatar
I went with 17" Carlini evils. The hardest part was pulling the wires thru the bars (use wire lube it is a life saver). I cut the plug off with 4" of wire left on the plug for splice. I had zero issues and yes I did have to extend, but if you are changing the bars and are going to run the wires internal then you may as well extend them.
The difference between you and me, is I run towards gunfire.
SBR_GUY is offline
post #5 of 14 (permalink) Old 09-03-2013, 03:20 AM
4getNo1's Avatar
Many members say that 12" is almost always max. IIRC, some have gone 14" but not many and can't remember which bars allowed that.
EDIT to match SBR update.
2013 FLTRX, Candy Orange
4getNo1 is offline
post #6 of 14 (permalink) Old 09-03-2013, 03:28 AM
SBR_GUY's Avatar
Sorry. I fixed my post. LOL
SBR_GUY is offline
post #7 of 14 (permalink) Old 09-03-2013, 03:34 AM
4getNo1's Avatar
No sweat SBR. Edited mine too so nobody can get confused at all.
4getNo1 is offline
post #8 of 14 (permalink) Old 09-03-2013, 03:55 AM
SBR_GUY's Avatar
LOL Thanks for pointing it out.
SBR_GUY is offline
post #9 of 14 (permalink) Old 09-03-2013, 04:27 AM
HellInABucket's Avatar
If you're 6-3, the first thing to worry about is to get the size of the bars right for you, and then worry about the wires. Why let cable or wire length dictate ride comfort?
2018 FLTRU
Roll away the dew...
HellInABucket is offline
post #10 of 14 (permalink) Old 09-03-2013, 05:30 AM
ybnorml's Avatar
My thoughts exactly.....
I'm 6'3" and went with 16" LA Choppers....
I have back trouble issues and slouch often, so the 16"s fit good....
Setting up straight the 18"s would work, but I can't set up straight.
Back to the original post....Buy the bars that fit your body then worry about cable length.
ybnorml is offline
Extending your brake line? This could save you money Sincecrazy Controls & Handlebars 1 07-16-2018 03:58 AM
SE Phat Plug Wires or OEM Plug Wires wevsspot *General Road Glide Discussions/Pictures 31 07-07-2017 10:17 AM
Extending FBW question 2015 RGS Clown Shoes Controls & Handlebars 11 03-22-2016 10:12 PM
Extending TBW wired BrewCitySinner Controls & Handlebars 14 12-16-2014 05:06 AM
extending FBW THEMASTERDESTROYER Controls & Handlebars 4 12-23-2013 10:04 AM
