Damn, I got a problem. - Road Glide Forums
post #1 of 23 (permalink) Old 09-06-2013, 01:26 PM Thread Starter
PFWiz's Avatar
Over the last few weeks I have started noticing problems in my handle bar radio controls. I lose volume up/down, menu (bass, treble...etc) I also lose CD track up, but strangely down works fine. Then I go over a bump and everything works fine for a while.
I was hoping to wait for the winter to troubleshoot the issue so I would not miss any riding time, but it seems to be happening more often. So even though it is 70 degrees and sunny I am about to pull the fairing and start poking around.
Hopefully it is just a loose connector.
If you have any ideas or suggestions please let me know.
PFWiz is offline
post #2 of 23 (permalink) Old 09-06-2013, 01:42 PM
HD4me's Avatar
Hopefully the problem is not on the inside of the Chuby's Outlaws.
Keep us posted on what you find. Good luck.
2011 FLTRUSE
1999 FLHRCI
HD4me is offline
post #3 of 23 (permalink) Old 09-06-2013, 01:49 PM
GlideShark's Avatar
Had similar problem and it was metal shavings/splinters around the inside of the drilled holes in the bars. Filed them down, made sure wires were good to go and no issues since. I have 14" outlaws
GlideShark is offline
post #4 of 23 (permalink) Old 09-06-2013, 01:50 PM
GlideShark's Avatar
Of course I waited until a wire was cut to do something about it lol
post #5 of 23 (permalink) Old 09-06-2013, 01:51 PM
GlideShark's Avatar
Sorry, damn mobile app.
post #6 of 23 (permalink) Old 09-06-2013, 02:01 PM
Sure sounds like connector, pace yourself as to it's working before puttin back together, trace trace trace.
reds4 is offline
post #7 of 23 (permalink) Old 09-06-2013, 02:45 PM
RhinoHD's Avatar
Check the Pink/White Wire
It's the common ground for the controls you described. Start There ask me how I know... LMAO
99% of the time its a bad ground issue...
Life is good but it's not easy!
RhinoHD is offline
post #8 of 23 (permalink) Old 09-06-2013, 02:46 PM
93-331-29psi's Avatar
You had to do this with Chubby bars? I've installed two pair on 2 different bikes and never seen sloppy holes in any of them.
93-331-29psi is offline
post #9 of 23 (permalink) Old 09-06-2013, 02:48 PM Thread Starter
PFWiz's Avatar
OK... Good news, bad news
Good news - Pulled the fairing checked the connectors and wiggled some wires. Everything works! I don't think I pulled anything hard enough to effect wires coming out of handle bars so I am pretty sure the problem located under the fairing.
Bad News - I don't have clue exactly where the problem is.
I did notice that the antenna plug on the back of the stereo was pulled half way out. I may have been a little too enthusiastic last time I bundled up all the under fairing wires / cables.
I guess the next step is to pull up a chair and a good light and inspect every wire / cable.... What fun...
I want to get this fixed so I can go to Thunder on the Strip in Geneva on the lake tomorrow.
PFWiz is offline
post #10 of 23 (permalink) Old 09-06-2013, 02:56 PM
OKBigD's Avatar
Check the connector... if you don't get them seated properly when putting the pins back in, they can back out after you connect them back to the wiring harness...
Disconnect it and look for a pin that is backed out......
OKBigD is offline
Damn--Won't start after bar swap. RedDogNC Controls & Handlebars 26 09-15-2016 09:35 PM
Damn hot today, 102 degrees FLtroll *General Road Glide Discussions/Pictures 21 06-05-2011 08:12 AM
Damn iPad! Howardsternspenis *General Road Glide Discussions/Pictures 0 03-15-2011 03:51 PM
yesterday was a damn good day... jedi General Off-Topic Discussions 5 03-13-2011 10:41 AM
Too damn funny!!! ThunderBueller *General Road Glide Discussions/Pictures 6 10-05-2010 10:57 AM
