Wild 1 Chubby install problem - HELP - Road Glide Forums
post #1 of 14 (permalink) Old 09-07-2013, 12:01 AM Thread Starter
Hey there everyone,
I'm in the middle of the install and come to find out there are no dimples in the bar for the control wires. Are Chubby's only for internal wiring? I'm pretty fuc#ed if so as I had to cut and solder the TBW
The bike is a 2013 FLTRX and I can't see anyway of getting on the front brake lever as the wires are in the way with a lack of any dimple (started the re-assembly on that side so the clutch is sure to be the same problem).
If they need to be internally wired does anyone have some clues as to how to snake the wires through? The right angle bend was such a bitch with the TBW I can't imagine trying to now add all the control wires.
Any and all help is appreciated.
Thanks,
Dean
Dean
2013 FLTRX
DeanFLTRX is offline
post #2 of 14 (permalink) Old 09-07-2013, 12:32 AM
Paul's Road Glide's Avatar
Dean, your up pretty late trying to install those chubby's, but check out my thread which might help you a little and yes they will need to be wired internally.
https://www.roadglide.org/showthread.php?t=17569
Paul's Road Glide is offline
post #3 of 14 (permalink) Old 09-07-2013, 12:50 AM Thread Starter
Arrrgggg
Paul, Yes I am. After reading through a bunch of posts, and the Wild 1 website (again) I came to the conclusion that, as you said, they need to be internally wired.
Took the bars off and am proceeding to undo all my soldering on the TBW. Might even get to hacking up the control harnesses before bed.
This weekend is supposed to be beautiful in PA, I just got my seat back from Mean City Cycles and really want to ride this weekend.
Thanks for the link to your post, I appreciate it. I can't wait to see how the combo of the bars and seat work for my 5'5" frame. Hopefully no more reaching.
Thanks again
Dean
PS: Pics will be taken once complete
Dean
2013 FLTRX
post #4 of 14 (permalink) Old 09-07-2013, 05:08 AM
Which Wild 1's. I put the 517's on and did not have a lot of problems with the internal wiring. I did get the CVO TBW with the longer wiring rather than soldering the original.
To pull the wires I put through a 12 gauge wire and used this as a pull tape. Also use some wire pull lube, you can get it at a Home Depot. The clutch side is easy, the brake side a little harder with both the TBW and the switch cables.
I took the wires out of the connected to avoid and splices as splices make the cable even bigger.
Dharn55 is offline
post #5 of 14 (permalink) Old 09-07-2013, 11:28 AM Thread Starter
I have 12" Chubby apes.
How do you remove the wires from the connectors? From the back side (wire) or from the connector side (pins)? If I can save myself soldering / insulating / wrapping 23 individual wires that would be a great thing!
Thanks for the help
Dean
Dean
2013 FLTRX
post #6 of 14 (permalink) Old 09-07-2013, 02:54 PM
doctor mike's Avatar
Do you have a manual?,if not on the back of the plugs theres numbers marked on them,I watched a you tube video on how to take them apart.harley makes a tool for pulling the pins but a stiff paperclip works as well.note what color wires are in what hole(look for the tracer color because theres a gray wire and a gray/white wire in same plug).on hd forums look for write ups by "dawg" he's really good on projects.I also get the se version TBW so theres no soldering.
BBP ULTRA,14" FACTORY 47 BARS,DAY MAKERS,MEAN MUG,JACKPOT 2-1-2,V&H MONSTER OVALS,WOODS 222 CAMS,MACH2 AC,POWER VISION,500 WATT J&M ROKKER 6 SPEAKERS,AGITATOR RIMS
doctor mike is offline
post #7 of 14 (permalink) Old 09-07-2013, 03:06 PM
roadglide007's Avatar
Yes you can remove wires from plug and put back together after. Remember to draw a diagram of the harness and label color by color wires. Good luck and YouTube is a great help
Sent from Motorcycle.com App
roadglide007 is offline
post #8 of 14 (permalink) Old 09-07-2013, 03:30 PM
the wild one web site has a wiring section that will help with pictures.
post #9 of 14 (permalink) Old 09-07-2013, 03:33 PM Thread Starter
Got it...went down to the stealer and he showed me how to unlock the wires and then release them from the connector.
Have all the connectors off and now I'm fighting to get them past the 90 degree bend....what a bitch.
I think I may take the award for longest time needed to install a handlebar!
Dean
Dean
2013 FLTRX
post #10 of 14 (permalink) Old 09-07-2013, 04:39 PM
Not even close. On my previous bile, an '01 Road King Classic I put on Wild 1 508's. I internally wire the switches (spliced so they were thicker than stock), heated hand grips and the wires for a set of J&M handlebar speakers. I had to modify the bars, make the holes bigger to fit all the wires , and it took me a couple of days to get it all done. It was unbelievably tight with all those wires. Heated hand grips and the J&M speakers were never meant to be internally wired.
Everything works great for a while, then the heated handgrips quit working (damn Harley grip fail all the time). I never did fix them.
Of course the bars did not have a 90 degree bend.
Another trick is to take of the OEM black cover and put on heat shrink covers that fit tighter.
Dharn55 is offline
Wild 1 Chubby install "Great Bars" mdemoulin Controls & Handlebars 11 07-23-2013 10:54 PM
14" Wild 1 Chubby Install fosterp Controls & Handlebars 23 01-18-2012 08:28 PM
Wild 1 515 Chubby Bars robojoe77 Controls & Handlebars 5 07-19-2010 12:13 AM
14" wild 1 Chubby's motodrummer Controls & Handlebars 9 06-01-2010 05:24 AM
Wild 1 Chubby WO517 RG smcgaug Controls & Handlebars 4 03-29-2010 12:59 PM
