Softbrake +2 extended brake lever info - Road Glide Forums
post #1 of 2 (permalink) Old 09-11-2013, 09:39 AM Thread Starter
Stalkker66's Avatar
Hey guys, I purchased the Kury extended break lever for my 2013 RG custom. I them lowered my boards with the Tall Boys lowering kit. Now the brake pedal is too high to be able to get at without lifting my leg off the board. I would rather just be able to rotate my ankle to get to the pedal. Has anyone installed the +2 extended softbrake lever and have some info of position over stock lever and some photos of it installed? Or if you have any other ideas? I was thinking over the winter i will remove and cut the cylinder that goes around the shaft and then mark were i want it positioned then reweld and gring smooth (maybe).
Stalkker66 is offline
post #2 of 2 (permalink) Old 09-13-2013, 08:02 AM Thread Starter
Stalkker66's Avatar
Update......I came up with a pretty good solution. Took me a few to go through with it since it was cutting off my new Kury extended brake pedal. So, I cut off the foot pad and ground smooth (which is ok since i am powder coating some stuff this winter). Drilled a hole at the end of the pedal arm that was lower then the foot pad and used a shifter peg. It is MUCH lower and further out front now and in a good spot to just curl your foot over. Plus it was a shifter peg i has laying around from my old fatboy. The only thing i may do later is just go to the store and find a stainless spacer to lengthen the peg about a half inch or so with a longer screw. Ill throw a few pics up this weekend to show you guys.
Extended brake lever for 2015 RG drricks Controls & Handlebars 18 10-16-2017 08:19 PM
Extended brake lever for '15 drricks Controls & Handlebars 0 10-28-2014 12:45 AM
Extended Brake/Shift Lever Question RoadGlideN8G *General Road Glide Discussions/Pictures 7 04-15-2014 10:06 AM
Kuryakyn Extended Brake Lever 1071 ilmanzo31 Classifieds Archive (3 months old+) 0 09-01-2012 07:03 PM
FS Softbrake slotted +1 brake lever longrides Classifieds Archive (3 months old+) 0 07-14-2011 06:14 PM
