Installing Heritage bars on a 2009 FLTR - Road Glide Forums
post #1 of 4 (permalink) Old 04-01-2010, 09:28 AM Thread Starter
Hey Guy's
Just scored a set of used heritage bars that I plan on installing on my 2009 RG, I have a service manual and I'm use to changing bars out on the old type cable throttle systems used in the past. Can anyone give me a step by step way to do this quickly and painlessly so I can save some time. I've got alot going on right now and I don't have alot of time to waste and I'm sure someone has done this enough to know all the little secrets. Thanks in advance.....
2
twowheel99 is offline
post #2 of 4 (permalink) Old 04-01-2010, 10:57 AM
1BigGuy's Avatar
the biggest piece of the process is that you have to remove the fairing to loosen the TBW cabling so it has enough slack to get the TBW control out the end of the bar to disconnect it. Other than that and reversing the same process, it's like most any other bike.
2010 FLTRX Black Denim
2007 FLSTN Vivid Black
1BigGuy is offline
post #3 of 4 (permalink) Old 04-01-2010, 11:53 AM Thread Starter
Is there a disconnect or do you have to pull the pins from the connector?
post #4 of 4 (permalink) Old 04-01-2010, 01:13 PM
FLTRI's Avatar
It's fairly easy to disconnect. Unplug it from the harness inside of the fairing first, and then feed it out of the end of the bar until you get to the plug, about 8". I had to do this when I installed the heated grips.
If you don't have one already, I'd suggest buying the service manual. It's outlined in it, and notes not to tug too hard or you'll break the plug requiring a new throttle position sensor...
Do your Heritage bars have a rather large oval hole at the base? If not, you're gonna have to make one to get the throttle wires inside of them...
Edit: I reread your post, and see you have the manual, sorry...
I hate that motorcycle they make me ride. I'm here to tell you there ain't nothing in the world I hate worse than that elephant under my ass.
Officer John Wintergreen reference his Electra Glide.
-Electra Glide in Blue, 1973-
FLTRI is offline
Stock Bars Vs. Heritage Bars cruisin62 Controls & Handlebars 19 01-17-2015 09:49 AM
Heritage bars w grips and stock bars FS CTVMotors Parts for Sale 1 04-27-2014 09:26 AM
Anyone switch from the Heritage bars to Yaffe 10" or 12" Monkey Bars? modot66 Controls & Handlebars 2 09-11-2012 02:35 PM
Heritage bars or CVO bars? Hawkeyestoob Controls & Handlebars 30 04-29-2012 08:11 PM
Heritage bars or Wide Glide bars cw821 Controls & Handlebars 2 12-31-2009 08:33 PM
