Front Turn Signal Mount - Road Glide Forums
 5Likes
  • 1 Post By Mike U
  • 1 Post By skratch
  • 2 Post By jeff338wm
  • 1 Post By ironmark
post #1 of 8 (permalink) Old 11-25-2016, 11:28 PM Thread Starter
rustyj671's Avatar
I've taken the fairing off so many times that I finally pulled one of the studs out of the turn signal mount. I tried to JB weld it into the mount, but when I tried to get it tight this evening, it just pulled out again.
Is there a suitable, STRONG, aftermarket replacement? If I buy a new stock HD one, PN 68933-04, I'm going to JB weld the stud in the hole to start with.
Thanks.
'12 FLTRX ==> PV w/ TT, PM Super Gas A/C, Dragos 580 cams, Fullsac DX pipe and 2" baffles in stock muffs, 18" Badseed bars, Custom Dynamics lighting, Dunlop AE tires, Aquatic Audio, JL Audio amp, Polk speakers, Progressive Monotubes, Alloy Art Stabilizer and Cush Drive, GMR Compensaver on SE compensator, Rush Cycle Pedic seat....all thanks to this forum.
rustyj671 is offline
post #2 of 8 (permalink) Old 11-26-2016, 08:36 AM
Mike U's Avatar
Rusty, I had the same problem with mine.
I replaced the studs with 5/16 - 18 Hex Head Bolts and haven't had a problem since.
If you want to keep the studs you can always use 5x16 -18 threaded rod.
Hope this helps.
Mike U.
Swomack likes this.
USMC 1975-1977
Semper Fi!
Nothing else matters!
Mike U is online now
post #3 of 8 (permalink) Old 11-26-2016, 09:32 AM
skratch's Avatar
how tight are you cranking on them acorn nuts? when you say 'pulled', are you saying that the stud came out of the turn signal with the threads and all, or twisted off when you turned the acorn nut 'lefty'?
I had one twist out with the acorn nut and I just took the nut off, put a dab of blue Loctite and screwed it back into the turn signal using the allen head recess on the stud. has never loosened again.
madmat likes this.
skratch is online now
post #4 of 8 (permalink) Old 11-26-2016, 10:29 AM
Used a piece of quarter inch something 'all thread, cut to length, within a couple threads and Nutted it on the inside. ...... not to long or it'll hit .....
reds4 is offline
post #5 of 8 (permalink) Old 11-26-2016, 03:49 PM
jeff338wm's Avatar
If you're going to work on Harley's...
better acquaint yourself with Heli-Coil thread inserts, available in any hardware or parts store.
Thanks.
direwolf and MightyWhitey like this.
'13 FLTRX Candy Orange w/ an upgrade here or there
jeff338wm is offline
post #6 of 8 (permalink) Old 11-27-2016, 09:16 AM
Had that happen to me, after so many time removing the outer fairing the threads stripped out on my turn signal housing. After trying JB weld and other stuff that didn't work I just called PC pain and ordered new housings, they aren't that expensive but you have to use the wiring harness that you already have unless you order a new one.
reds4 likes this.
post #7 of 8 (permalink) Old 11-27-2016, 10:01 AM
direwolf's Avatar
Happened to me on my 08 so many times that I finally switched out to the "Alloy Art Led Turn Signals"
...2009 SERG...Last of the Hand Built's..
direwolf is offline
post #8 of 8 (permalink) Old 11-28-2016, 01:50 PM Thread Starter
rustyj671's Avatar
I had already used RED loctite to get it to stay in the housing. Oh well, I went ahead and ordered a pair of new ones. The left side will give up eventually.
Flush mount turn signal jstucker1976 Lighting 1 06-19-2013 06:01 PM
10" Windvest. front and rear turn signals. Rear mount and pegs and highway peg mount. 1346wildcat Parts for Sale 10 04-23-2013 07:34 PM
Kuryakyn front turn signal locate harness kimmer127 Lighting 2 12-06-2011 02:45 AM
Front turn signal modifications CMS *General Road Glide Discussions/Pictures 16 05-09-2011 11:54 PM
Front Turn Signal Powder Coating PhrogFlyer *General Road Glide Discussions/Pictures 6 01-27-2011 12:48 PM
