Street Glide/TRX rear light bar on Ultra
I've read the posts that I could find about this but can't find an answer. I want to run a Custom/Street Glide type rear turn signal bar on my 2012 Ultra. I found a bar on CL and got Custom Dynamics 1157 LED's and a badlands load equalizer. I want to be able to have the light bar work in addition to the ultra brake light, with all three lights working as run and brake lights and the small lights as signals. So basically like a Custom with an added center brake light. I'm also running a tribar light in the fascia as well.
My issue is figuring out where to connect everything in the brake light base. There are slots for the brake light, the turn signals and the tri-bar, which has a run and brake circuit as well as a ground (picture attached). I already soldered the wires for the plate light into the running and ground wires on one of the lights, so that doesn't need a connection. I can take the connector for the tri-bar and split it, running one to the tri-bar and the other to light bar. But that will only give me the option of having run/brake or run/turn on the signal lights. If I hook up the brake circuit and then apply the brakes the flash signal won't have any affect.
Does anyone know if I get the run/turn/brake module will that let me run the dual filament 1157 bulbs and how would I need to wire it up?
