Help identifying led ground effect kit - Road Glide Forums
post #1 of 5 (permalink) Old 03-02-2017, 05:47 PM Thread Starter
Hey guys and gals, I need some help identifying what led kit I have. My FLTRUSE came with led effect lights that didn't work. I took the seat off and found a crushed wire and a blown 10amp fuse. The crushed wires are on a pigtail from the controller box. There is no marking on the box. I have pictures of the key fobs, broken wires and the controller box. What say you?
Mtguns is offline
post #2 of 5 (permalink) Old 03-03-2017, 12:29 PM
Mach1's Avatar
I had something similar installed on my V-rod to remotely control the air ride. The key fob and box are just generic wireless transmitters and receiver used as a switch. Usually around $20 on amazon. I'd just solder the crushed wires back together.
Mach1 is offline
post #3 of 5 (permalink) Old 03-03-2017, 12:41 PM
slowglide2989's Avatar
Its a Chinese model. I have the same controller for mine with completely different LEDs on my Can-Am. Can't you just repair the wiring and reroute them out of harms way?
slowglide2989 is offline
post #4 of 5 (permalink) Old 03-03-2017, 02:48 PM
Bevis's Avatar
Did a repair on my buddys bike yesterday from the same thing. I soldered in extended the wires, and rerouted them. His fobs now turn his leds on whenever he wants. We couldn't kind any markings on the box either.
Bevis is offline
post #5 of 5 (permalink) Old 03-14-2017, 02:04 PM Thread Starter
I went to see if I could make this repair today and low and behold there was an unused plug that was taped over. I unplugged the damaged pigtail popped in a good 10amp fuse and now my lights work just fine. I ended up taping the damaged pigtail up and put everything back together. I will probably go back and make the real repairs to the pigtail when I get the proper parts. None of the auto stores around here had what i needed so I impatiently bought what they had to make it work.
Mtguns is offline
Need help identifying existing suspension on a used bike. ZX2BY2U Suspensions 10 09-07-2017 10:29 PM
Help Identifying HD touring seat macabra11 Seating: seats, backrests 6 05-20-2017 01:04 AM
Help identifying vibration please.. cookie114 Troubleshooting for Road Glides 6 07-16-2016 02:05 PM
Help Identifying Head Pipes on 2010 RGC Gixxere *General Road Glide Discussions/Pictures 5 01-21-2015 11:17 AM
Need help identifying this screw. Triplej *General Road Glide Discussions/Pictures 24 06-03-2013 11:55 PM
