What gauge wire? - Road Glide Forums
post #1 of 4 (permalink) Old 03-11-2017, 02:13 PM Thread Starter
89FXRS's Avatar
What gauge wire?
trying to convert from a FLTRX to a CVO tail light section - need to know what gauge wire is used on the CVO-stop,turn,+ brake lights. Also where can it be bought? thanks - FXRS
If you're talking behind my back - then you're in a good place to kiss my ass!!!
89FXRS is offline
post #2 of 4 (permalink) Old 03-11-2017, 03:01 PM
Thermodyne's Avatar
16 and 18 gauge is what they are wired with. They sell that sized wire in almost any auto parts store. Thing is that the tool to crimp the late style wire ends on with is expensive, as are the wire ends and connector housings.
What year fender asm to what year scooter are you doing.
I would probably start with the fender harness that fits the fender, that way all the connectors to the lamps are there.
Then if you get lucky, it will plug right into the existing plug on the scooter. If not, you'll only have the wires at that one connector to sort out. Probably just the need to splice them into the original connector.
If your scooter is new enough to have cannbuss, then you might run into some issues with that.
Thermodyne is offline
post #3 of 4 (permalink) Old 03-11-2017, 03:11 PM Thread Starter
89FXRS's Avatar
18 gauge wire will not fit inside the deutsch connector or the deutsch pin that is used to connect the tail lights - and the bike is a 2013
89FXRS is offline
post #4 of 4 (permalink) Old 03-11-2017, 04:24 PM
Thermodyne's Avatar
Are you talking about the little flat connector back where the lamps plug in? Those are not Deutsh. They are Tyco/AMP multilock something or other. They use a terminal all their own and an AMP tool to crimp them. I've never done much more than release the terminals from them and plug them into other connector housings. Never crimped one or had that tool in my hand. The ones I've seen on Harleys are 18-20 gauge wire, just by looking at it.
Tire pressure gauge & tire depth gauge cobra206 Miscellaneous for Sale 1 12-04-2016 11:37 AM
What gauge amp wire you running? jeffbeck96 Audio 14 01-15-2014 06:45 PM
What gauge wire extensions are needed? 2012FLTRU_BigBlue Controls & Handlebars 5 04-10-2013 02:11 AM
Oil temp gauge wanted (gauge only, not full kit" SickRick Wanted! (Buy or Trade) 0 04-08-2013 03:54 PM
wire gauge????? boudie Controls & Handlebars 2 05-21-2011 04:19 PM
