Canadian rear fender to U.S. rear CVO fender - Road Glide Forums
post #1 of 11 (permalink) Old 03-18-2013, 11:47 AM Thread Starter
Hello all I am about to change out my rear canadian stock fender with center tail brake light to the U.S. cvo rear fender. Does anyone know if it is a straight plug and play or is there more to it than that? Thanks for any input.
mikehall11 is offline
post #2 of 11 (permalink) Old 03-18-2013, 12:11 PM
Question
I was thinking of same set up ,
Maybe we will get some input also would
Like to do bag extensions was thinking of
The ones from cyclesmiths they said
The flat black is a match for the denum
Paint , I have seen a few pics with this set
Up but not in person .
bigmatt1967 is offline
post #3 of 11 (permalink) Old 03-18-2013, 12:22 PM Thread Starter
I did the Harley bag extensions had them painted the vivid black, they were fairly simple.
post #4 of 11 (permalink) Old 03-18-2013, 04:24 PM
Youll need to get the yaffe stealth 3 license plate bracket the cover the hole where the center light was mounted. I had the center light too and converted to the cvo fascia. I had to re-pin the stock harness to make the cvo harness work. Youll be able to use your stock fender by the way
post #5 of 11 (permalink) Old 03-18-2013, 04:29 PM
The plate bracket mounts directly to the exisiting holes that the center light mounted to. This is again my stock fender
post #6 of 11 (permalink) Old 03-18-2013, 05:15 PM Thread Starter
I have the full cvo kit that comes from harley I also have the stealth 3 plate kit. Is there a template I can get anywhere for the wire pin change or is it fairly straight forward. I Know how to take the plugs apart as I need to when I wired my BR bars.
post #7 of 11 (permalink) Old 03-18-2013, 07:08 PM
I pieced everything out seperately and was able to save a few hundred bucks. As far as the plate frame, i just cut and spliced the wires together since theres only the two wires for the plate light. That harness is under the seat. As for the light harness i re-pinned the factory harness which is relatively easy. You can buy a direct plug and play harness from the dealer for about $30 if you so choose to make it really easy for you.
post #8 of 11 (permalink) Old 03-20-2013, 02:04 PM Thread Starter
I'm in the middle of changing the wire harness plug but I have a left over orange wire with white stripe that I believe is for a brake light. Do I just omit this wire or will that create a fault signal in the computer turning on a warning light ?
post #9 of 11 (permalink) Old 03-21-2013, 06:36 PM Thread Starter
Solved the wiring problem the orange wire with white strip on Canadian bikes needs to be wired to the blue wire on the CVO fascia lights. When wired color to color there is no receptor wire for the orange white on the fascia side. Had signals and brakes but no power to the running lights or the plate light. I switched the orange white feed to the blue wire in the fascia harness and everything worked perfectly.
post #10 of 11 (permalink) Old 03-21-2013, 09:15 PM
Glad you got figured out. Now get some pics up so we can check it out
Rear Bag lights on Canadian 16 RGS HDRGGriz Lighting 7 11-07-2017 06:00 AM
Fender fascia light (Canadian RG) Back n black Lighting 3 02-02-2016 09:24 AM
Canadian vs. American Rear Fender justcuz007 Lighting 3 12-26-2015 05:28 PM
CVO Ultra / CUSTOM Rear fender with CVO Fascia jokercraze Sold 10 09-20-2012 09:20 PM
