Adding run brake and turn to your King tour pack? - Road Glide Forums
 2Likes
  • 1 Post By jethro_3
post #1 of 9 (permalink) Old 05-26-2017, 06:38 PM Thread Starter
steventammy's Avatar
Hi all
We have an 11' Road Glide Ultra CVO and already have the Custom Dynamics LED white with Amber turns on the front
Now I'm looking to convert our rear tourpack to "run brake and flash"
Anyone do it, what was needed? Works like a charm?
Sent from my SM-G935P using Tapatalk
Steve & Tammy
2011 CVO Road Glide Ultra
steventammy is offline
post #2 of 9 (permalink) Old 05-26-2017, 08:26 PM
hawwk's Avatar
I like your bike and the color. Going to subscribe to this thread. My tour pack the center lights with the brakes but would like the left and right corner to work as signals too
hawwk is offline
post #3 of 9 (permalink) Old 05-26-2017, 11:46 PM
I also have the same 11 red CVO. I made the turn signals a red run/brake/turn and then added the Led run/brake/turn under the saddle bag. Kid says in the daylight it looks like a fire truck when I hit the brake at almost a 1/4 mile.
On the CVO forum they have a thread on how to make the sides turn signals.
hawwk likes this.
jethro_3 is offline
post #4 of 9 (permalink) Old 05-27-2017, 10:37 AM
SurlyBoy's Avatar
Not a hunert percent sure if it's different for the CVO, but if you have a run turn brake module for your rear turn signals then there is a small wiring harness that you can plug in after the module that will add that function to your tour pak. I believe it also makes the side lights work as turn signals.
Something like this
Kuryakyn Run-Turn-Brake Wiring Harness for Tour-Pak | 160-816 | J&P Cycles
SurlyBoy is offline
post #5 of 9 (permalink) Old 05-27-2017, 12:09 PM
I'd give Custom Dynamics a call,,, They are extremely knowledgeable about the differences of the years, models, etc... Or you could check out CVO Harley,, they pretty much know what they're doing,,, a Great bunch of folks...
HeatWave is offline
post #6 of 9 (permalink) Old 05-27-2017, 02:15 PM
Something like this
That piece will require some rewiring as the LED CVO king is just a bit different. I looked at that also and no go.
hawwk likes this.
jethro_3 is offline
post #7 of 9 (permalink) Old 05-28-2017, 12:15 AM
SurlyBoy's Avatar
Yeah, probably not that exact part. I was just using it to show the type of part that will work.
SurlyBoy is offline
post #8 of 9 (permalink) Old 05-28-2017, 12:20 AM Thread Starter
Too bad custom dynamics isn't open until Monday, I'm wanting to get this done
Steve & Tammy
post #9 of 9 (permalink) Old 08-20-2017, 05:37 PM
MidNightRGU's Avatar
Hello?
Any Updates out there?
MidNightRGU is offline
adding a HD king tour pak SEUGOT1 Equipment-RG 5 06-13-2018 09:13 AM
Adding King Tour Pak (with lights) to a Special psrumors Tech Area 15 02-24-2018 02:04 PM
adding turn signal lights in tour pack???? kentucky cowboy Lighting 5 03-21-2013 11:56 AM
Help! Run,turn,brake on older tour pak Sealdoggy Lighting 3 02-28-2012 10:56 PM
LED King Tour-Pak Brake/Turn/Tail Lamp Kit on '11 RGU Lu Lighting 13 12-29-2010 12:55 PM
