LED Fillerz plus Saddlebag LED - how do I wire them together?
I recently installed the LED Rear Fillerz on my 16 FLTRU as per instructions and running with brake, turn, run modes. I installed harness under seat as directed. Now I would like to add the rear saddle bag lights as well but also in the run, brake, turn mode. Does anyone have an idea how to do this? Is there a y connector I can buy to hook these also into the harness under the seat? Can the electrical system handle it in view of the Can Bus?
Lots of questions - thanks for the help.
djbethany
Sponsored Links | |||
Well what saddlebag lights are you using? CD or HD? the HD ones come with a P&P harness. The CD ones, I assume you used the CD harness with the posi-taps? If so you should be able to just double up with the red posi-taps..
If CD, you will need a turn signal decoder...may as well get a mpr adapter too.
I have both of the HD kits on my ride-just installed the bag lights last weekend in fact. Both use y-harness's under the seat, it's all included with each kit.
2016 Cosmic Blue Pearl RGU
2002 883R Sportster
Thread Tools | |
Display Modes | |
Similar Threads | ||||
Custom Dynamics Fillerz | SharkBite | Lighting | 19 | 06-24-2018 08:45 PM |
How do I wire in LED Accent liters on 17 RGS? | Slider57 | Lighting | 1 | 01-27-2018 03:09 PM |
Custom Dynamics Fillerz $175 | conn-e-rot | Parts for Sale | 3 | 12-26-2017 08:56 AM |
Couple final questions before I wire and put her back together this weekend. | hometoast | Audio | 5 | 03-21-2014 01:31 PM |
Finally back together, what do u think(be honest) | Maybelle | *General Road Glide Discussions/Pictures | 52 | 05-28-2013 05:44 PM |
Posting Rules | |
