Daymaker Fog Light Help Needed - Road Glide Forums
post #1 of 13 (permalink) Old 06-04-2017, 06:53 PM Thread Starter
maczter's Avatar
I finished wiring up my Daymaker Fog lights last night. Turn signals work correctly, the switch lights up and you can hear the relay click, but I get no lights on the fog lights. Have triple checked my connections, and according to the instructions, I have it all connected.
I used kits:
Road Glide LED Fog Lamp Mount Kit - Chrome, #68000183
Auxiliary Power Switch Kit - Fairing Mount #71400105
Daymaker Reflector LED Fog Lamps - Chrome Housing #68000090
No power at the lamps, or at least the connection that I spliced into. I traced out that wire, blue/blk strip, and it goes all the way into the body harness according to the manual. Here's my thought though...where does the power get to that wire? I am thinking that connector (4) on the harness needs to be connected to something on the bike, but have no idea what. Since the harness gives outputs for Acc2 and Acc3, and the instructions say to use the far right switch, is it possible this is Acc3? If so, what is the harness connector supposed to plug into? Lastly, is it POSSIBLE that the fuse for my radio would also control these lights? I have pulled that fuse until I can get the radio flashed this week due to a Boom II upgrade.
HELP!!!!!
2016 FLHRUSE w/VH Monster Ovals, American Head Pipes, VH FP3 Tuner, Klock Werks 14" tinted wind screen, Harley Boom II Upgrade, Minibeast 2 Air Horn
maczter is offline
post #2 of 13 (permalink) Old 06-04-2017, 09:20 PM
I have to see the part number for the switch, but I also have Daymaker driving lamps. I don't have a relay, I hooked the switch into the left side of the instrument panel, (won't work on right side), then hooked the harness in with the turn signals and it works fine. I did it on my 16 and 17.
post #3 of 13 (permalink) Old 06-04-2017, 10:50 PM Thread Starter
maczter's Avatar
Did you have the connector already underneath the dummy block? I did, plugged it in there and then added the harness to distro center under the fuse box. I am so freakin' confused. My dash switches came with two on the right and center, and a blank on the left. Saw somewhere on a forum post a member added another switch on the far left for his fog lights. Do I need to add that?
maczter is offline
post #4 of 13 (permalink) Old 06-04-2017, 11:17 PM
The only thing I had to add was the switch to the left side, the wires were already there, and I had to hook the driving lamps to the harness that went to the turn signals. I didn't have to do anything to the fuse box.
post #5 of 13 (permalink) Old 06-05-2017, 12:08 AM Thread Starter
maczter's Avatar
OK, that may be may be my issue then. I will see if the dealer has that switch tomorrow....grrr. But thank you to ton!
maczter is offline
post #6 of 13 (permalink) Old 06-05-2017, 03:19 AM
Bevis's Avatar
put the radio fuse back in and see if that answers you question, if Acc 3 runs off radio fuse.
Bevis is offline
post #7 of 13 (permalink) Old 06-05-2017, 07:19 AM
Ohiobellboy's Avatar
Get that radio flashed while you're there.
Sent from my XT1254 using Tapatalk
A.K.A OBB
Ohiobellboy is offline
post #8 of 13 (permalink) Old 06-05-2017, 12:12 PM Thread Starter
maczter's Avatar
A little more information...read on the HD website another rider was having a similar issue and he had to install the fog lamp switch, PN 71400044, in the dash. Got one this morning, installed and still no lights. Bike goes into the shop on Thursday for service, am having them look at it if no one here chimes in.
maczter is offline
post #9 of 13 (permalink) Old 06-05-2017, 02:16 PM
BH#103's Avatar
I am slowly collecting the parts to put the fog lamps on my fairing. I already installed the switch kit on my bike and use switch #2 to power my Garmin. Before I installed the switch assembly I put the fog lamp button in #1 position. If I looked at this right, the fog lights will get their power from the empty terminal on the turn signal connector. Anyone able to confirm if this is correct?
BH#103 is offline
post #10 of 13 (permalink) Old 06-06-2017, 07:31 AM
I just found my invoice:
1 68000090 Kit-Fog Lamp, Bullet Chrome
2 68000170 Kit-Mntg,Fog Lt, Touring
3 69200172 Switch Asy, Dashpanel Mtnd
4. 69201109 Kit-Wire Harness, Fog Lamp
This was all I needed, hooked up with no problem, BTW I bought everything from Jon (PC Pain) at Horny Toad HD.
GMONEY likes this.
Daymaker Reflector LED Fog Lamps - Chrome Housing NEW $300-BRO chriscalabro Parts for Sale 4 01-13-2017 03:54 PM
New Daymaker Reflector LED Fog lamps Ohiobellboy Lighting 67 09-29-2016 05:37 AM
Daymaker Fog Lights jeaves726 Lighting 9 08-09-2016 06:03 AM
Daymaker Reflector LED Fog Lamps Q-Hog Lighting 4 02-26-2016 03:17 PM
Daymaker fog lights moose1 *General Road Glide Discussions/Pictures 7 12-31-2014 08:36 AM
