Screw sizes in front signals - Road Glide Forums
post #1 of 4 (permalink) Old 08-10-2017, 11:22 AM Thread Starter
BigChief's Avatar
Can someone tell me the size of the screws/bolts in a 2015 Road Glide front turn signals or where I can get them from? Tried Harley no luck. Thanks in advance
BigChief is offline
post #2 of 4 (permalink) Old 08-10-2017, 02:08 PM
wevsspot's Avatar
Hey Chief, the problem you're running into is that the Harley parts diagram doesn't list that bolt in the parts diagram. However I believe that the inner bolt for the turn signal stalk and the outer bolt for the turn signal stalk are the same part number. I'm assuming that you need the outer bolt?
Take the spare bolt you have up to the dealership and ask for HD Part Number 4816A. Then compare the two.
wevsspot is offline
post #3 of 4 (permalink) Old 08-10-2017, 02:22 PM
wevsspot's Avatar
Hey Chief, I stand corrected. While the parts diagram for our 2015 bikes does not show that outer bolt, the parts diagram for the 2016 Road Glide does show that outer bolt. I'm not sure what the difference is between the inner and outer bolts, but the correct part numbers for the bolts are;
Turn Signal Stalk Inner Bolt - 4816A
Turn Signal Stalk Outer Bolt - 10200350
To be clear, the outer bolt I'm talking about is the allen head bolt that you can access at the rear of the turn signal stalk. These would be the two you would need to remove as part of the fairing removal procedure. Any dealership ought to be able to order them as long as you have the part numbers.
Illustration attached.
Hope this helps.
wevsspot is offline
post #4 of 4 (permalink) Old 08-11-2017, 07:34 AM Thread Starter
BigChief's Avatar
Hope this helps.
Hi and I realy appreacite the help. I was able to fiannly get the dimension of all the screws and bolts and found them all at home Depot. Bike is back together and ready to ride, well after I figure out what the red light on the speedo mean? Its on and Red while riding..
BigChief is offline
Carlini 17" Evil Apes - Cable Sizes? redbeard719 Controls & Handlebars 2 10-18-2012 11:54 PM
carlini 14" flying apes (cable sizes) mroach Controls & Handlebars 9 02-27-2012 08:12 PM
Wheel sizes Wharf Rat Road Glide Specific Discussions 4 02-16-2012 11:17 PM
Windshield sizes BigLew Windshields 0 04-28-2011 12:12 PM
Tires sizes dont make sense need HELP beachbum Aftermarket Accessories 4 10-11-2010 06:37 PM
